Does anyone know of any example USB outlets that can be fitted, ideally in the blank to the left of the fog light switch?
If there are better places to fit the outlets, then I'd be keen to know that instead.
Thanks in advance.
Richard.
Posted 23 December 2018 - 10:35 PM
Thanks in advance.
Richard.
Posted 23 December 2018 - 11:10 PM
Posted 23 December 2018 - 11:12 PM
Posted 23 December 2018 - 11:28 PM
Posted 23 December 2018 - 11:54 PM
Posted 24 December 2018 - 01:06 AM
It does, there's a dog leg bracket to a captive screw.
Same location as this visible screw head on a Mk1. I suppose you could make up a new bracket, but there must be a better location to have cables hanging loose. How about in the glove box or repurposing the ashtray with a phone holder?
Posted 24 December 2018 - 10:35 AM
If you can find one the right diameter there won't be much behind it. Although the hole will need opening up as I think it has a flat edge ... to stop what was there on other cars (heater?) turning.
Posted 24 December 2018 - 10:37 AM
Edited by CityEPete, 24 December 2018 - 10:41 AM.
Posted 24 December 2018 - 10:47 AM
Posted 24 December 2018 - 12:31 PM
Posted 24 December 2018 - 12:41 PM
Choke cable! ?If you can find one the right diameter there won't be much behind it. Although the hole will need opening up as I think it has a flat edge ... to stop what was there on other cars (heater?) turning.
Posted 24 December 2018 - 02:30 PM
RHD or LHD ?? ?Choke cable! ?If you can find one the right diameter there won't be much behind it. Although the hole will need opening up as I think it has a flat edge ... to stop what was there on other cars (heater?) turning.
Posted 28 December 2018 - 08:01 PM
Hi,
Thanks for all your replies.
I've chosen to get the below and fit it between the heater and steering wheel:
https://www.ebay.co....aCgVl:rk:5:pf:0
I know I will need to open one of the holes up to be big enough for the dual USB outlets.
