Rear Disc Calipers
31 replies to this topic
#16 minibugga
minibugga
  • 87 posts
Posted 13 January 2019 - 10:48 PM
Quick tip: put the lower shock bolt the opposite way around to avoid having to take off the wheel, caliper and disc if you have to change the driveshaft or similar.
Gonzo
#17 Renessy
Renessy
  • 306 posts
  • Local Club: minisevenclub Holland
Posted 15 January 2019 - 12:11 AM
Oke,
Glad Gonzo could help you.
But…..
It turns out that we don’t have the same calipers after all.
I did some research and came to the conclusion that I have:
Ford Sierra 18. CVH 2wd calipers. Model 88-93
R/H Caliper number 0658/4
For anybody who needs and wants to know.
#18 drmandy
drmandy
  • 35 posts
Posted 27 February 2019 - 05:33 AM
Thanks Gonzo,
Really appreciate the help. I will try to source the pads with your #s
Mandy
#19 26dtp
26dtp
  • 42 posts
Posted 30 March 2020 - 03:46 AM
Hoping someone can help me out here, especially Mandy and Gonzo!
I am currently upgrading my rear brakes from the sierra calipers to the Renault/Citroen ones. However, when I put it all together to tack in the new mounts (supplied by zcars) for the new calipers, they do not line up on the hub:
Attached File  IMG_20200329_173619-min.jpg   35.13K   1 downloads
Attached File  IMG_20200329_173626-min.jpg   33.3K   2 downloads
Attached File  IMG_20200329_173657-min.jpg   59.39K   1 downloads
Attached File  IMG_20200329_173729-min.jpg   46.15K   1 downloads
The calipers are the same as Mandy's. Here they are compared to the (what I believe to be) sierra calipers:
Attached File  IMG_20200329_162712-min.jpg   99.29K   1 downloads
Here are the all the details of the pads (FDB877/GBD905):
Attached File  IMG_20200329_180601-min.jpg   37.96K   0 downloads
Attached File  IMG_20200329_180631-min.jpg   45.86K   0 downloads
Retainer clips:
Attached File  IMG_20200329_180608-min.jpg   41.22K   1 downloads
Attached File  IMG_20200329_180633-min.jpg   62.01K   1 downloads
Discs:
Attached File  IMG_20200329_173855.jpg   74.21K   3 downloads
Attached File  IMG_20200329_175443.jpg   49.69K   6 downloads
Is anyone able to tell me if these match what they have and whether or not I am doing something wrong. 2 thoughts I have:
First is that I am using the tubular rear swingarms, not the box. Maybe the size/length of the hubs are different? They don't look different! Here is mine after I cut off the old caliper mounts:
Attached File  IMG_20200329_162630-min.jpg   57.71K   1 downloads
My other theory is maybe the discs are the wrong kind because I was also having trouble getting the caliper+pads on the disc, though it is very close. If you see above it says the discs are for honda and mg...nothing about renault's.
Hopefully someone is able to tell me what i'm doing wrong and at the very least, maybe this information is useful to someone out there! Cheers :)
#20 sonscar
sonscar
  • 2,987 posts
Posted 30 March 2020 - 09:30 AM
Without being "hands on"it is difficult to be definate but I would not think that was a showstopper.Pack it out with metal or wood or something,tiewrap it in place solidly and try the wheels.Does everything rotate/clear look good?Yes? get a curved plate to match the hub and weld the brackets to it.Brakes are a sensitive system to fabricate so take this advice at your own risk.Steve..
#21 26dtp
26dtp
  • 42 posts
Posted 30 March 2020 - 03:49 PM
Thanks for your thoughts Steve. That is definitely an option and one I will take if I have to. It just seems weird that mine doesn't match up but others do. If you look at Mandy's picture on the first page his matches up fine so want to make sure I have the right setup and not missing something obvious before I start modifying hub/making new brackets to support it.
Edited by 26dtp, 30 March 2020 - 04:00 PM.
#22 Painter man
Painter man
  • 85 posts
Posted 30 March 2020 - 06:46 PM
If you ask gonzo he will supply you the brackets to weld on as they are different to the ford hangers I have the cotton hangers on my busa kit and yes the fit is a tight fit when the pads and discs are new
#23 Painter man
Painter man
  • 85 posts
Posted 30 March 2020 - 06:47 PM
Citron
#24 26dtp
26dtp
  • 42 posts
Posted 31 March 2020 - 04:20 AM
Thank you for reply, good to know they are tight. I will have another go but they are really tight...like hammer the pads in tight, so I didnt want to risk damaging anything.
As for the brackets, I believe I have the correct brackets. The holes line up perfectly and they fit onto the hub perfectly....until I place the caliper onto the disc and put the disc onto the hub and then they do not line up, which is why I am thinking it could be the disc Here are the brackets:
Attached File  Optimized-IMG_20180102_203414.jpg   29.42K   1 downloads
#25 26dtp
26dtp
  • 42 posts
Posted 01 April 2020 - 01:47 AM
I'm starting to wonder if it is the rotors. I was able to get the caliper on them with the pads. When i tested them in the wheel (ultralite 13x7 et-7) it feels like it is making contact and rubbing.
Attached File  IMG_20200331_180726-min.jpg   47.15K   1 downloads
Attached File  IMG_20200331_180717-min.jpg   43.58K   2 downloads
Attached File  IMG_20200331_180748-min.jpg   42.21K   1 downloads
Do folks use wheel spacers in the rear?
Anyone have information what rotors I should be using to I can see if I have the right ones?
Cheers!
Edited by 26dtp, 01 April 2020 - 01:51 AM.
#26 26dtp
26dtp
  • 42 posts
Posted 09 April 2020 - 04:50 AM
To close the loop here I think I have solved my problem! http://www.theminifo...uild/?p=3641692
#27 Renessy
Renessy
  • 306 posts
Posted 10 April 2020 - 07:54 PM
You can also make the discs smaller....  :shy:
#28 26dtp
26dtp
  • 42 posts
Posted 14 April 2020 - 12:20 AM
That would work for the clearance of the rim but I also needed the rotors to be deeper so the caliper mounts would line up with the arm to weld.
#29 Lexqlusive
Lexqlusive
    Just On Tickover
  • 7 posts
Posted 23 January 2023 - 07:05 AM
Hi,
As I’m continuing my Zcars build, I’m searching for the part number or vehicle type the rear discs are from.
I’m using Peugeot/Citroën callipers.
Can anyone tell me what vehicle type I need to search on?
#30 Painter man
Painter man
  • 85 posts
Posted 03 February 2023 - 06:36 PM
My kit was brought in 2015 from Zcars In Hull I have a hayabusa fitted and believe my rear brakes to be off a citron Saxo I have new spares in the workshop I can send the part number I’d the discs
