I am not sure if you mentioned what engine you have, 1275 or 980 or 1098? but the stiffness of the C clip and the "Backing Ring - washer thingamajig" whilst being fitted to the crankshaft does not sound too good.
Whilst you have the primary gear out you can check the idler gear float using a dial indicator.
Building engines and gearboxes requires absolute cleanliness, patience, assemble/disassemble until everything fits and rotates correctly with minimal friction.
It is so sad to see an engine/gearbox poorly built and a few 100 miles down the line seeing it all end with damaged internals, never mind the expense and tears.
Good luck in the new year.
Hi Rorf,
Sorry, it's a 998 A+ and I absolutely agree with your comment.
Unfortunately, living in central London has it's drawbacks. In fact it has many drawbacks including not having a garage or workshop at or near home in my case. Once I'd disassembled the engine/gearbox, everything was taken home, to much delight of the wife (
), where I cleaned everything and oiled to protect until I got a chance to get back to the garage to reassemble everything. Given I have an underground, poorly lit, garage, I tried to make sure everything was cleaned and measured correctly. My problems seem to have been caused by new parts being fitted such as in baulk rings, which seized the gearbox, and the c-clip backing ring which, as stated on Minispares website, are produced oversize to allow for wear. As my original backing ring did not have any signs of wear or damage, I re-used this with noticeable difference as explained above.
I did check the idler gear end float when the engine/gearbox were separated but as I have a DTI, there's no harm in double checking. Am I right in saying this is done by fitting the DTI at 90 degrees with the tip through the crank hole up against the idler gear and seeing how much movement the idler gear has?
Many thanks.
Edited by Its a min, 30 December 2018 - 11:22 PM.
