Best Way To Remove Engine
4 replies to this topic
#1 Minimanda
Minimanda
    Starting My Mini Up
  • 4 posts
Posted 08 December 2018 - 01:22 PM
Hi new to the forum just brought a 1990 Mayfair. Only problem engine took head off I have 1 broken piston.
What is the best way to remove engine?
#2 johnR
johnR
  • 2,297 posts
Posted 08 December 2018 - 05:46 PM
The 'best way' is to get someone else who's done it before do it for you - failing that: Disconnect battery. Remove alternator, carb(s) brake master and servo and any other parts blocking removal. Split top balljoints on front suspension which will allow you to pop the drive shafts out of the diff (drain oil before you do this)  disconnect gear selector from back of gearbox (by driving rollpin out) Disconnect control cables/speedo cable. Check nothing is still connecting the engine to the car including wires such as the big cable to the starter motor. Undo bolts on engine mounts and any steadies (head and gearbox usually) Use straps or chains and an engine crane or block and tackle to lift out. The Haynes manual will help you with the detail of removing it if you haven't done much mechanicking before.
Edited by johnR, 08 December 2018 - 05:49 PM.
#3 greenwheels
greenwheels
  • 687 posts
  • Local Club: Mini Fixers
Posted 08 December 2018 - 08:04 PM
Good description from johnR. Just remember it doessn't lift straight out - you have to lift it so it tilts backwards a bit to get the dif out. Try to adjust the straps/chains so you are lifting above the front head studs, i.e. in front of the cg, and it should tilt back just right.
#4 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 09 December 2018 - 11:26 PM
Welcome to TMF
You don't need to crack the ball joints to pull the pot joints out of the diff
It's a lot easier to  the pot joints out initially and then juggle them out by swinging the engine once its lifted
You can keep it on its wheels then too
Reverse procedure when dropping the engine back in
#5 Minimanda
Minimanda
    Starting My Mini Up
  • 4 posts
Posted 10 December 2018 - 08:12 AM
Cheers all for the advice I am a determined female who likes to get her hands dirty,I have Richie my partner giving me advice .
Will update how things progress
