Fan Spacer
#31
Posted 29 November 2018 - 06:51 PM
The centre point of the tips of the blades are in line with the mid point of the lip on the shroud which is what is needed.
I recall a car years ago where the owner or the engine builder had cropped about 5 mm from the end of each blade. They did this on a rally car so that if the car hit a big bump the rubber radiator mountings did not cause the shroud to hit the fan when the rad and shroud moved relative to the fan/pulley. The car was overheating because of this. The solution was/is to bolt the radiator directly to the mountings with no rubber bushes.
#32
Posted 04 December 2018 - 02:57 PM
How can I check that the correct top bracket is fitted for this 1990 998
what spacer is on it? if just one 4mm it may be better with 2 of them. and does it have the correct top bracket fitted?
#33
Posted 04 December 2018 - 03:37 PM
it will fit with 2 holes to the thermostat and 2 holes to the rad cowling. and will be made from one piece of metal.
#34
Posted 06 December 2018 - 06:07 AM
#35
Posted 26 December 2018 - 09:26 PM
Cooperman/Nicklouse
This is mine (1990 998) I believe it to be as it was intended. Thoughts?
Edited by cooperd70, 28 December 2018 - 10:50 AM.
#36
Posted 28 December 2018 - 10:50 AM
Finally got to mine and have taken a look and there is one 4mm spacer. Also the rad top bracket is one piece and two bolt mounts on both sides of the bracket. So another 4mm may do it perhaps?
#37
Posted 18 March 2019 - 06:28 AM
http://www.minispare.../C-ARA4401.aspx
Original fan is removed when installing this kit and have set the replacement to kick in at around 85c.
It works a treat and I can't believe how efficient it is at pulling air through the rad and into the wheel arch. Just the ticket for being in traffic jams this coming summer with all the mini gatherings going on for the b'day celebrations.
#38
Posted 18 March 2019 - 05:32 PM
I'd be surprised if it can reliably push enough air through the rad at speed.
#39
Posted 18 March 2019 - 08:01 PM
In fact I dare say the cooling would actually be better at speed if there was no fans there at all - they just become an obstruction.
#40
Posted 18 March 2019 - 08:52 PM
38 Replies to this topic - where is the lad going - really?
His head will be mashed !!!
#41
Posted 18 March 2019 - 08:55 PM
It doesn’t need to push (or actually pull) air through the rad at speed, just as the standard one doesn’t.
I get that with a front mounted rad on the move but not a side mounted one. I wouldn't have thought there's sufficient volume of air flow though it to cool adequately. I'd expect an electric fan to run constantly in that situation and still struggle to cope, they're not really designed to run continually.
Time will tell I guess.
#42
Posted 18 March 2019 - 09:07 PM
So mine had the correct top bracket, correct 4mm spacer, but as Nick suggested was just too far out of the lip of the cowling and so decided to fit this to bring cooling up to modern standards:
i would still keep the mech fan as there is a lot of work to do as the area in the wing is a high pressure area and it gets it harder to push air out of the wing the faster the car travels.
#43
Posted 18 March 2019 - 10:00 PM
#44
Posted 19 March 2019 - 06:19 AM
I fitted two additional 4mm fan spacers to the end of the water pump so I could keep the original fan bolts (so they didn't bottom out). So can always refit the mech fan if desired, but the kit instructions are specific to fitting to a mini.
It is very efficient at pulling air from the engine bay through the rad and out under the wing. at standstill just popping you hand under the wheel arch you can really feel the amount of hot air it's shifting.
