Upgrades On A 1275Cc Classic Mini
6 replies to this topic
#1 Agus1601
Agus1601
  • 148 posts
  • Local Club: La Tribu Mini
Posted 25 November 2018 - 03:29 PM
HI guys! I have my car running very good atm but still need some more power!
My spec engine is this one:
- 1275 A+ engine
- +0,30 piston
- Full stg 1 kit (RC40 maniflow + k&n + bits)
- 123 distributor
- bosch grey coil
- champion n9yc sparks
- lucas performance lead set 8mm
- aluminum 3 core radiator
- hs4 carb with some tweaks (needle + spring)
- 3,44 original gearbox
I would like to get aprox 90bhp at the flywheel, so lets do a buy bits list to make that possible
Things I have:
- Lightened flywheel
- hif 44 (not in perfect working condition) a lot of needles, etc
I have been able to make it run like this
Any thoughts?
Edited by Agus1601, 25 November 2018 - 03:29 PM.
#2 Steve220
Steve220
  • 5,043 posts
  • Local Club: BMC
Posted 25 November 2018 - 03:45 PM
A decent cam and headwork. After that, forced induction!
#3 nicklouse
  • 18,559 posts
Posted 25 November 2018 - 03:52 PM
get it set up on a rolling road. the dizzy aint the best for the Mini.
#4 ukcooper
ukcooper
  • 1,625 posts
Posted 25 November 2018 - 06:27 PM
as steve said
276 cam week car 286 track / weekend car
decent head stage 3 as called see turbophil
lighten the mini - tool; box and spare wheel sub box ect
rolling road as said will help a lot lot after ya finished working on the spec's
Edited by ukcooper, 25 November 2018 - 06:28 PM.
#5 Cooperman
  • 23,273 posts
Posted 25 November 2018 - 06:42 PM
For a genuine 90 bhp at the flywheel you will need, as a basis, a really well gas-flowed head and a better cam.
Once you have these you should add an lcb exhaust manifold, a well-matched inlet manifold and a modified HIF44 carb.
Match these to an accurately assembled block/crank/piston assembly with a better distributor and you should achieve the 90 bhp figure.
However, to use this better power you will need a suitable final drive ratio.
#6 mikal
mikal
  • 240 posts
Posted 25 November 2018 - 08:03 PM
Gear ratios?
#7 Cooperman
  • 23,273 posts
Posted 25 November 2018 - 09:19 PM
A modified engine giving 90 bhp will give its peak power and peak torque at higher revs than a standard engine.
Thus it may be necessary to run a lower final drive ratio in order to optimise the overall performance.
One modifies an engine to improve the performance, so it is a good idea to match the gearing to the engine torque. For good overall performance a 3.44:1 FDR can be a good ratio as it is the same as the original Cooper 'S' 1275.
