Unfortunately I need to replace my stub axle, but I am having troubles removing it. I tried using a hub puller (not sure if that's the correct English word for it, link is down below), but the puller actually sheared because of the amount of force required. So I was wondering, what is the correct method to remove a stub axle? Leaving the radius arm on the car would be highly preferred.
Thanks in advance!
