Rocker Nut Torque
4 replies to this topic
#1 croc7
croc7
  • 809 posts
Posted 19 November 2018 - 07:12 AM
Other than just ‘nip them up’ what’s the proper torque on the rocker adjustment nuts when adjusting valve clearance?
#2 Spider
  • 14,849 posts
Posted 19 November 2018 - 07:36 AM
For the Sintered type Rockers - 16 ft / lbs
#3 croc7
croc7
  • 809 posts
Posted 20 November 2018 - 02:40 AM
Wow, never thought that it would be that high. Is that standard torque for that size thread or special for that application in the valve train? Thanks
#4 Spider
  • 14,849 posts
Posted 20 November 2018 - 04:22 AM
That's the standard torque for the factory item.
As mentioned, that's the figure given for the Sintered type Rockers, which use the 5/16" UNF / 1/2" AF Hex Nuts, not the earlier M7 / 7/16" AF Hex Nuts.
#5 croc7
croc7
  • 809 posts
Posted 20 November 2018 - 04:35 AM
