Clutch Pedal Return Spring
2 replies to this topic
#1 jime17
jime17
  • 948 posts
  • Local Club: None
Posted 10 November 2018 - 04:22 PM
1991 mayfair
Verto clutch.
servo brake
Hi all, Just ordering bits so I can start my auto/manual conversion.
Got a clutch pedal given to me. Not sure about the return spring side of things.
Logic says to me that currently I will have the spring that has only the leg that pulls up the brake pedal and that I need a new spring that has two legs, one for the brake and one for the clutch pedal with the tang in the centre that acts against the pedal box..
The parts catalogue however seems to show the single leg one (with the leg on the left)  where it would hook under the clutch pedal only.
Does this mean that the servo cars don't have a spring to return the brake pedal? I'm a bit confused.
TIA,
Jim
#2 nicklouse
  • 18,577 posts
Posted 10 November 2018 - 04:27 PM
servo cars have it on the pivot in the engine bay IIRC
#3 jime17
jime17
  • 948 posts
  • Local Club: None
Posted 10 November 2018 - 05:42 PM
Thanks Nick.
So the single lever spring for the clutch pedal only would seem to be the correct one?
I guess if minispares site says it then it must be right. Thanks for clearing it up,
