Brighter Headlight Bulbs
Posted 06 November 2018 - 12:01 PM
Is there a good upgrade to the headlights with better bulbs that will improve night time driving? I don’t really want to fit new headlights, just fit better bulbs if possible.
Posted 06 November 2018 - 12:24 PM
first thing to do is check the wiring. check that you are getting the same voltage at the connection to the lamp and you are getting across the battery. if it is less you may want to renew or replace part of the loom. or bypass it with some relays and new wiring.
Posted 06 November 2018 - 12:29 PM
Posted 06 November 2018 - 01:01 PM
What bulbs have you got? The large round bulb or sealed beams ? You might be better off converting to at least H4 bulbs
Posted 06 November 2018 - 01:03 PM
You can get a 100/80 watt halogen bulb from Demon Tweeks. You will need to up-grade the wiring and, ideally, fit relays for dip & main beam. It makes the lights well up to modern driving, but make sure the alternator can handle the additional drain if you are also using spot or driving auxiliary lights.
Edited to add that if you have the horrible 'electric candle' sealed beam units you will need to fit new light units for halogen bulbs. I was assuming that you already had halogen H4 bulbs fitted. The best headlights are the Cibie ones or the Hella H4 units. A good low cost alternative are Autopal as they look fairly original.
Edited by Cooperman, 06 November 2018 - 01:06 PM.
Posted 06 November 2018 - 06:28 PM
You can fit brighter bulbs and it may help (I have 100 / 160 in mine), but if the Headlamp assembly and in particular, the reflector and inside of the glass isn't up to scratch, then brighter bulbs will make little difference.
Posted 06 November 2018 - 08:57 PM
Which headlight assemblies do you use? I've got Wipac Freeforms to go into my car when I build it up. You reckon they are up to scratch for brighter bulbs?
Posted 06 November 2018 - 09:39 PM
Hi mate,
To be honest, I couldn't say other than they are made in Taiwan! I get them from my local Parts Supplier, while they are inexpensive, they do work much better than the Hellas that I had.
I can't say if yours would be up to scratch, you can only try them.
Posted 07 November 2018 - 12:52 AM
There are regulations about bulb ratings to consider. Standard 60/55watt H4's should be perfectly adequate, it that's what you have and they're not, as above look for faults.
Does it have dim/dip, it's about the right age I think.
Posted 09 November 2018 - 03:38 PM
Buy yourself some Cibie (don't skimp on cheap) lenses and some decent H4 bulbs (Osram or Phillips). It'll make all the difference.
Posted 13 November 2018 - 10:45 PM
Hi guys
Just bought myself a 1997 mini cooper. The headlights are not that bright, however the full beam seems to be okay- not great though.
I see some people above recommending changing the bulbs, and some recommend changing wiring or units etc.
Can anyone recommend what worked for them? I believe its the standard unit and bulbs i have installed.
I am also looking to upgrade my rear lights. Can anyone recommend on make and model of lights to go for?
Reason for upgrade is the current ones are not very good in the winter- not bright enough
Many thanks
Sean
Posted 16 November 2018 - 03:57 PM
I was just searching on this subject as my current solution is to avoid driving at night....I my Chinese bicycle light is brighter than the mini's headlights.
Are there any LED conversion kits out there, that people have used?
Posted 16 November 2018 - 08:30 PM
Posted 16 November 2018 - 08:59 PM
Minispares now sell an "E" maked LED headlight. No picture yet on the website but I think its the new Wipac ones. Be interested to hear from anyone who has tried them.
Posted 17 November 2018 - 06:56 AM
That is a crazy price!
just came across this guy who brought some H4 LED bulbs from aliexpress -
and came across some on amazon - https://www.amazon.c...BTYXEXRW1E&th=1
Edited by dangerousdowning, 17 November 2018 - 07:03 AM.
