thanks for the replys i have tryed heating it up and i placed the engine in between to big blocks of wood so it wouldnt move and it still will not budge anymore ideas please also ano this might sound stupid but the pictures that have been posted dont look anything like my flywheel i only have the flywheel on i dont have any of that metal plate or anything is that supposed to be on
and also i have taken the thermastat out of the engine and there is a load of brown stuff looks like sludgey sand a hope that makes sencecan anyone help me with this please
Well mine is a Verto clutch, so it is going to look a bit different from a pre-verto, which should look like this:
Pre-Verto clutch
The Chinese hat looking thing (diaphragm) is going to fasten to the flywheel, and you can see the holes where your flywheel puller bolts go. This is what yours looks like, right?
So you've got the flywheel bolt out. And then you've taken the keyway out:
Keyway
And then you've aligned your crank so that they C-shaped washer holding the primary gear on can't slip down and block flywheel removal (someone else will have to help me out here....what is the crank orientation for the pre-verto setup?)
Primary gear C ring..
Primary gear backing ring
If all that holds true, then it's just down to persistence and the right tools for the job.
thank you for all your replys i appreciate them alot without your help i would be f****d i have had the pressure plate of its the flywheel that i cant get off
many thanks will try again in the morning and hopefuuly get it off
