Need Help With My Nuts...... Wheel Nuts!
10 replies to this topic
#1 mini_mezza
mini_mezza
  • 226 posts
Posted 01 November 2018 - 06:35 PM
can anyone point me in the direction of a new set of these? a web link would be great!
45215931_535920521456_892865950278641254
They are off a set of BWA 10" (similar to the GB alloys)
m_m
#2 nicklouse
  • 18,355 posts
Posted 01 November 2018 - 07:04 PM
http://www.minispare...px|Back to shop
#3 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 01 November 2018 - 11:28 PM
Give em 9 months and they will look just the same Chrome these days is crap
Buy stainless if you can
#4 nicklouse
  • 18,355 posts
Posted 02 November 2018 - 01:22 AM
would never use stainless wheel nuts.
#5 cooperdan
cooperdan
  • 3,729 posts
  • Local Club: N/A
Posted 02 November 2018 - 06:05 AM
Why is that just out interest nick?
#6 Arthy
Arthy
  • 112 posts
Posted 02 November 2018 - 07:35 AM
To my knowledge a lot of split rim wheels use stainless nuts?
#7 nicklouse
  • 18,355 posts
Posted 02 November 2018 - 09:02 AM
well it all depends on the grade of steel used.
but the threads need lubricating or they can gall. and in some places any lubricant on a wheel retaining thread is not permitted.
 stainless steel is often nowhere the correct strength needed in these applications.
and it can also rust.
as a side effect the studs will corrode faster than is a normal steel nut was used.
now don't get me wrong there are suitable stainless steels out there but they tend to be expensive.
as with most things it come down to the actual spec of the material used and not the type of material. and knowing what spec you need and then getting that info from the seller and then actually believing the seller....
#8 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 02 November 2018 - 10:45 AM
KAD don't have an issue with stainless nuts, and neither do I and many others
Stainless is better than the cheap crappy bar turned toffee dusted in sparkly rubbish offerings, all day any day
Yes the bolts on the split rims are stainless too
Why ?  because the anodized bolts were deteriorating
#9 mini_mezza
mini_mezza
  • 226 posts
Posted 06 November 2018 - 10:00 PM
Buying new ones as current ones have been over tightened and knackered the threads! Not too bothered about the look!
m_m
#10 nicklouse
  • 18,355 posts
Posted 06 November 2018 - 10:36 PM
means nothing without knowing the material grade. and they are not nuts.  can not see any stainless wheel nuts on KADs pages.
stainless is on of the most overrated materials out there. and without knowing what spec it is it should not be used in areas that require a high tensile load.
would you use a stainless steel head nut? with a tensile strength that is less than a third of a suitable head nut? dont think so. but there are people selling such crap out there.
#11 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 06 November 2018 - 11:44 PM
https://kentautodeve...eel-spare-bolts
Stainless...
Weather you call em bolts, nuts or sleeve nuts they are still tightened up and hold the wheels on
Could  KAD  risk selling them if they were toffee ?
