Mainstream Cooper Restomod, Germany
roundnose
63 replies to this topic
#61 MaximMini
MaximMini
  • 226 posts
Posted 27 March 2022 - 04:56 PM
Hi Everyone,
This week I carried on with the L/H door (or doors since I actually built two). My mate had generously painted the inside of the frame and door skin for me so that the rust prevention was complete when I came in the workshop. So, I started with applying some sound deadening.
before preparing frame and skin for welding and folding action
Tried on and plug welded
Folded and fully welded
And all ground and finished
On the body for appreciation ;-)
With the door done I was confident to finally cut back the A-panel and prepare with rust converter
And that was it for this week ..
Cheers from the Pied Piper's Town
#62 MaximMini
MaximMini
  • 226 posts
Posted 13 April 2022 - 11:06 AM
Hi Everyone,
Not much progress since my last update.
The week before last week I spend another day in the workshop mainly disassembling the remaining parts on the body shell. I should probably done that from the very start but then I never intended to get that deep into the bodywork ..
With the dampers on the front out of the way I finally disassembled the damper mounts only to find the usual horror beneath.
Which cleaned up like this
WVmUKwp.jpg?1
And that's where I left actually looking forward to repairing this relatively straight forward section.
But live had other plans and I was tested positive on SARS-Cov-2 and am in isolation since.
#63 MaximMini
MaximMini
  • 226 posts
Posted 01 May 2022 - 10:04 AM
Hi Everyone,
With the isolation done I have spend some more time in the workshop.
Firstly I build a transport frame which I will use when the body goes to the paint shop. The frame is based on a sturdy metal frame with rollers which I bought cheaply and that I have added wodden beams and clamps to:
Next I carried on with the repair sections behind the front shock absorber mounts which meant cleaning the right hand side:
Before making the repair sections from sheet steel:
The repair sections are hold in by hope only until the welding gas bottle has been refilled :shy: .
And that was that for this week. Due to change in jobs the progress will slow down in the near future unfortunately. But than, I will work for a company that does laser welding and cutting machines which will open up some very interesting opportunities :D .
Have a look into my engine and gearbox project thread in case you want to know how I spend my isolation at home.
Cheers fro the Pied Piper's Town
#64 MaximMini
MaximMini
  • 226 posts
Posted 22 October 2023 - 05:45 PM
Hi Everyone,
It's been 16 month since my last post :shy: ! Time that I needed to settle into my new job.
But since June I have spend some tiime in the workshop again and finally got around to finishing the welding :D .
It startet withe the damper mounts, where I left with the repsir panels made and ready for welding.
Next I finally got the chance to use my newly accured spot welder (for the last of the spot welds of the restauration) when welding in the L/H A-panel
Followed by the repair of the upper dash rail
And then yesterday the last two little repair areas. First the roof rail
And then a patch below the R/H head lamp
And that was it. Sure it didn't all went all as I hoped for but that it's all done by myself.
Next on the agenda is the preparation of the underside before all the last preparation before the body can be send out to the paintshop.
