New Hif 44 Stubstack Design
10 replies to this topic
#1 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 31 October 2018 - 09:55 AM
New design
TMF price £30
Turbo Phil tested the old ones at over 5% flow increase, these should improve on that.
http://www.retromini...roducts_id=1017
They will only fit the HIF44 carb and can use the standard screws to fit
Has slots on the back for the dashpot vents
Engineered in England  so they actually fit
#2 ukcooper
ukcooper
  • 1,625 posts
Posted 31 October 2018 - 11:05 AM
looks good and I would have but have  mpi now  :shy:  :shy:  :shy:  :shy:  :shy:  :shy:
#3 Icey
Icey
  • 1,552 posts
Posted 31 October 2018 - 12:56 PM
How does it compare to the MED stack (£25)?
#4 luismx123
luismx123
  • 525 posts
Posted 31 October 2018 - 01:13 PM
Is there something like this for a hs4/hif38?
#5 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 31 October 2018 - 08:38 PM
Don't know how they compare to MED ones maybe Turbo Phil has tested them
They are based on Vizard type ones but we put the slots in the back which should help the airflow more
For 1 1/2 inch carbs H4 Hs4 and HIF 38
http://www.retromini...roducts_id=1241
#6 nicklouse
  • 18,689 posts
Posted 01 November 2018 - 01:53 AM
one thing i have often wondered with the HIF carbs is they already have a radiused opening so would these not be better having a extension going into the carb to smoothen that out? as that step and radius can not be good for flow.
#7 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 01 November 2018 - 09:46 AM
I think the slight radius at the mouth on HIF carbs gives them a slight advantage over the HS type when it comes to bare flow
Compared to a bare carb a stubstack will flow over 5% more.
Air will flow round a 15 degree un-radiused corner without any losses
The flow loss starts once the flow separates from the surface which it will at an angle tighter than 15 degree
The concept is to get minimal flow separation, by reducing turbulence and thus increasing laminar flow
Think TOLL booth
A bare carb suffers "vena contracta"   https://en.wikipedia.../Vena_contracta
A 6mm radius is difficult to improve on
David Vizards findings and comments follow the above
Turbo Phil tested the earlier version and measured a flow increase of over 5 % which is perfectly inline with David Vizards figures
#8 luismx123
luismx123
  • 525 posts
Posted 01 November 2018 - 09:52 AM
stupid question but does one add a filter ontop of the substack?
#9 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 01 November 2018 - 10:10 AM
Thats up to you but a nice K&N is best, by that I mean not a cone type
The stubstacks are designed to go inside the filter
#10 luismx123
luismx123
  • 525 posts
Posted 02 November 2018 - 09:46 AM
Why wouldnt you recommend the cone type for the sub stack?
Im guessing one would have to match the metal fitting to the inlet first, then throw the substack inside. is it because of space or the way the air wants to flow in there?
Which filter is in the picture above? classic pancake?
#11 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 02 November 2018 - 10:32 AM
The one above is a pancake K&N withan offset hole on an HS4
I am no fan of cone filters, the only real advantage is easy to fit, but not good for power, plenty of noise though.
https://www.calverst...air-filtration/
