Micra Inlet Manifold
Posted 22 October 2018 - 05:40 PM
Posted 22 October 2018 - 05:41 PM
Hi,
I would think the stainless flange is for the exhaust?
Posted 22 October 2018 - 05:51 PM
Hi,
Second one down definitely inlet.
Posted 22 October 2018 - 05:59 PM
Hi,
Well in that case you'll have to buy injector bosses, pipework and a throttle body flange and get it all tigged together.
Do fusion fabs make one or can the original be cut down and welded back together?
Another alternative would be some motorbike throttle bodies and use those with some stubs and silicon hoses on to that stainless flange.
Posted 22 October 2018 - 07:07 PM
Posted 23 October 2018 - 06:58 PM
I've got a Jenvy throttle body sitting for a later mod and was planning on making a carbon fibre plenum and runners bonded to the original flange and injectors. Should be easy enough!
Posted 23 October 2018 - 09:11 PM
Assuming you can TIG weld you can make one up. I used a 4 inch 180 degree bent pipe that I got from eBay. I'll try to get a photo up.
I have a mate down the road who can fit I just have to make it and he will weld it up what size 90 bends did you use
Posted 26 October 2018 - 01:41 PM
Posted 26 October 2018 - 01:42 PM
Posted 10 November 2018 - 09:44 AM
Posted 10 November 2018 - 10:04 AM
Blimey looking at that new one mine might be due for a part ex haha
