Jump Start Booster Pack Advice
11 replies to this topic
#1 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 19 October 2018 - 07:41 PM
My mini let me down this morning, would not start. It was pretty cold at around 0c.
Engine is recently built, high compression (if that matters). The engine has a k1100 head and runs efi
I am using my old and standard starter, (maybe I need a high torque starter) .
I have looked at booster starters before, but to a bit of "analysis paralysis" so didnt actually buy one. If I am honest I am still a bit confused.
I see you can get small slim line booster packs (look like a laptop battery), these seem to be around 300a - 400a
Or there is more traditional boosters (the ones with handles) that are around  800a - 1000a, obviously these are built more tough to store in a mini.
Any advice on what to buy?
Craig
#2 klivins
klivins
  • 317 posts
  • Local Club: minimania.lv
Posted 19 October 2018 - 08:08 PM
I live in place where -20 is common. mini starts fine with20w50 oil even in -10. Check your battery, starter motor, and Electric connections prior to investing in booster packs!
#3 ukcooper
ukcooper
  • 1,625 posts
Posted 19 October 2018 - 08:14 PM
i bought that one https://www.machinem...jumpstart-1010/
rather heavy , but works well
tyre inflator well worth it
unto a 2l diesel so murders a mini mpi
#4 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 19 October 2018 - 08:20 PM
I'd not waste money buying those little booster packs,
A. they are only designed to dump their charge into your battery and they won't jump start anything (see the size of the leads)
B. They don't last very long.
C. its a marketing con to even suggest something that small could provide enough amps for any length of time.
I have see far to many fail on the first attempt,in as little as 3 secs = fried pack, not a nice smell
Buy one of the bigger jump start packs, but first do a check on your current electrical system, charge rate and battery condition, are you running the bigger fitment of a 075 battery? good earths and connections are a must to prevent volt drop
#5 sledgehammer
sledgehammer
  • 3,098 posts
Posted 19 October 2018 - 09:06 PM
as above , check all leads & terminals ,
it only takes a slightly loose connection , corrosion , or a frayed earth cable to slow the starter
battery terminals are also a good place to look , esp the non clamping lead one , with screw in the middle
#6 Wiggy
Wiggy
  • 1,036 posts
Posted 19 October 2018 - 10:31 PM
I'm too tight to buy a jump pack, so I keep an old battery on a trickle charger next to a set of jump leads. Which is what a jump pack is, in effect.
#7 Bat
Bat
  • 903 posts
Posted 19 October 2018 - 10:42 PM
Hi,
As stated check everything on the car, then if none the wiser you may have a lazy starter motor.
I buy Aldi jump start packs the old one actually seems better than the new one!
Maybe it just needs to see more action?
Cheers  :proud:
#8 JCmini
JCmini
  • 146 posts
Posted 26 October 2018 - 11:33 AM
https://www.amazon.c...8YCYV5G38CYQJV7
I bought one of these cheap small charger. Worked perfect for me. Got me out of many troubles.
#9 phil hill
phil hill
  • 616 posts
Posted 26 October 2018 - 01:55 PM
I would echo the above advice: check security of connections at battery, boot earth, engine to body earth etc.
If the starter is still slow maybe it's due a service or overhaul.
If your battery is "tired" or has been allowed to go flat on occasion then it may be reduced in capacity - it doesn't take much, a resting voltage of 12v indicates the battery is dying rather than "ok". If the car is left alone for periods of time this where a quality trickle charger or even a solar charger can save the day.
I would recommend a decent branded battery like Varta C6, Bosch S4 or similar in size 063, or if you're feeling flush an Optima RTS 4.2
Phil.
#10 nicklouse
  • 18,579 posts
Posted 26 October 2018 - 01:59 PM
as much as I like the idea of these I have issues. needs to be kept in the garage/hose to make sure it is always charged. so if you are at work...... opps.
a spare charged battery in the garage and some jump leads in the car are way better. and most likely work out much cheaper.
I would start with putting the current battery on charge for a few days to make sure it is well charged. (if you have a charger that reconditions the battery even better).
#11 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 28 October 2018 - 08:44 PM
Thanks guys!
The plot thickens - The car actually started the day after all of this. I hadn't even charged the battery.
So i guess it is the starter or my timing might be a bit out.
#12 croc7
croc7
  • 809 posts
Posted 29 October 2018 - 04:56 AM
For a jump start kit-a product called ‘JUMP n Carry’. Faster than RAC, ADAC or AAA, for about $100. Fits nicely under a mini seat, only needs to be re-charged every three months.
Edited by croc7, 29 October 2018 - 06:34 PM.
