Brake Leak
16 replies to this topic
#1 CoenZ
CoenZ
  • 39 posts
Posted 13 October 2018 - 10:58 AM
Noticed today that the brake fluid reservoir had slowly emptied. Followed the brake lines and found that the line connected to the caliper was leaking at the connection... see picture. What are my best options you guys think?
* Just use some teflon tape?
* replace fitting?
* Replace full brakeline?
* Other?
  Attached File  Capture.JPG   33.33K   10 downloads
#2 RedRuby
RedRuby
  • 1,201 posts
  • Local Club: No
Posted 13 October 2018 - 11:09 AM
Not 100% sure but should there not be a copper washer between the flexi pipe and calliper body.
If you look at the attached link it is showing the copper washers on the Male ends.
http://www.minispare...0/C-AJJ4030.jpg
Edited by RedRuby, 13 October 2018 - 11:13 AM.
#3 CoenZ
CoenZ
  • 39 posts
Posted 13 October 2018 - 11:24 AM
Here is the other side, no leaks.... and there is quite some space to cover for washers.
Attached File  Capture.JPG   23.04K   2 downloads
#4 A-Cell
A-Cell
  • 1,610 posts
Posted 13 October 2018 - 01:25 PM
The specification calls for a copper washer. This is mandatory to prevent leaking.
Mini spares sell them.
http://www.minispare...49.aspx|Back to
#5 Bat
Bat
  • 903 posts
Posted 13 October 2018 - 01:36 PM
Hi,
Unless it's a taper thread, unlikely in aluminium castings, then a copper washer should be used.
Cheers  :proud:
#6 nicklouse
  • 18,577 posts
Posted 13 October 2018 - 01:42 PM
something wrong there. what is the caliper? what make of hose?
my first thought is the hose has not been made correctly. and as other have said there should be a copper washer there. but your hose does not fit correctly.
so could be a hose or a caliper issue.
#7 motorwise
motorwise
  • 18 posts
Posted 13 October 2018 - 03:28 PM
the pipe should seal on the taper at the end check the seat inside the caliper and the thread ... if it doesn't go down tight it will leak
#8 nicklouse
  • 18,577 posts
Posted 13 October 2018 - 03:45 PM
not on a Mini
#9 harrythehat
harrythehat
  • 275 posts
Posted 13 October 2018 - 04:15 PM
find a copper washer that fits inside Boom fixed
#10 motorwise
motorwise
  • 18 posts
not on a Mini
look at the end of the pipe and the one fitted on the other side isn't leaking it's clearly tapered
#11 harrythehat
harrythehat
  • 275 posts
Posted 13 October 2018 - 04:22 PM
are the calipers OEM
#12 motorwise
motorwise
  • 18 posts
Posted 13 October 2018 - 04:30 PM
i'd say not looking at them .... hence the different sealing method
#13 CoenZ
CoenZ
  • 39 posts
Posted 13 October 2018 - 05:28 PM
They are Wilwood calipers and have 1/8 NPT thread inside. Both breaklines are the same (non tapered) but are a tight fit with the right threads. I will try some copper washers, that makes sense to me.... thanks for all the help and suggestions!
#14 motorwise
motorwise
  • 18 posts
Posted 13 October 2018 - 06:33 PM
i thought they looked aftermarket the pipe in the picture has a tapered seat .... that's where it seals inside the caliper ... you've get a lot of space there to take up with washers and more than one washer will still leak .... check the seat inside the hole and the seat on the pipe for damage this is almost certainly where your fault lies
#15 Painter man
Painter man
  • 86 posts
Posted 13 October 2018 - 07:38 PM
If they are wilwood calliper they should have a taper thread so the correct way to seal is loctite 636 it’s the proper sealant for them put int on the thread and leave it to go off
