Primary Gear Oil Seal Tool
8 replies to this topic
#1 ings
ings
  • 200 posts
Posted 12 October 2018 - 04:12 PM
I have the minispares primary gear oil seal tool.
One to slide the new seal over the gears and one to push the primary gear back in place by using the big center bolt.
But how can i remove the primary gear?
#2 ukcooper
ukcooper
  • 1,625 posts
Posted 12 October 2018 - 04:33 PM
there a tool for that ass well don't make em new just old one's about ......
put the seal off with out damaging it a the bush will just come off ..
make sure you uae the propa tool for putting back on or wrap the splines in tape to stop it leaking ans set in to the right depth or it will leak
#3 nicklouse
  • 18,400 posts
Posted 12 October 2018 - 04:38 PM
pull it and let it twist if it wants to.
#4 ukcooper
ukcooper
  • 1,625 posts
Posted 12 October 2018 - 04:42 PM
the one in the pic ...ps..search oil seal tool noy removel tool ..
Attached File  s-l1600.jpg   54.26K   2 downloads
its like the oil seal tool  but cut in half with a lip on the out side to slot in the gear then ya put the bolt in and iy pops off summit like that
I have two off em but just had me leg cut off or id get better pics as there diwn the shed soz
edit spelling
Edited by ukcooper, 12 October 2018 - 04:51 PM.
#5 Spider
  • 14,665 posts
Posted 12 October 2018 - 05:24 PM
These are the only ones I know of for sale;-
http://minisport.com...l-removing-tool
I made mine about 30 years ago.
#6 DeadSquare
DeadSquare
  • 3,044 posts
Posted 12 October 2018 - 08:17 PM
If you are replacing it, the oil seal doesn't need a special tool to remove it;  Just dig the oil seal out, carefully, with a thin screwdriver hammered between it and the casting.
Having removed the oil seal, remove the "C" washer and the primary gear can be with-drawn.
Edited by DeadSquare, 12 October 2018 - 08:25 PM.
#7 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,020 posts
Posted 12 October 2018 - 08:55 PM
I made my own, pretty easy if you have access to a welder, grinder, drill and a few other bit's.
 so dad got some 65mm ID tube cut it up and made the bolt end for it out of 6mm plate and the other a U shape with a ~48mm ID to match the gear groove and I welded together and drilled and tapped it M12. which got us something similar to the standard tool, used an old main bolt and drilled it a little to centre the tool bolt. and gave it a lick of paint
7F76C6DF-A5E9-429C-87BD-71DAE5A44D73_zps
599D25D0-9A96-4B07-AD89-6A8D6A870BC6_zps
#8 Spider
  • 14,665 posts
Posted 12 October 2018 - 09:54 PM
I'll just add to this be very very careful if removing it this or by similar methods (self tapper etc) as it's not easy to work in there, access is limited and so it's very easy to damage other parts.
#9 ings
ings
  • 200 posts
Posted 15 October 2018 - 06:38 AM
I removed the final gear with a super large screwdriver... installation with the special tool. no oil leaks anymore from there. :-)
