Fluctuating Idle With Vacuum Advance Tube Connected.
Posted 03 October 2018 - 12:54 AM
Posted 03 October 2018 - 07:58 AM
What Carb(s) are you running?
Posted 03 October 2018 - 08:26 AM
Single Hif44
Posted 03 October 2018 - 08:55 AM
Ah, OK.
The Port on these Carbs is usually in a less than desirable place for Distributor Vacuum Advance.
On all other SUs, it is Ported such that at Idle, you don't get much or any Vacuum, however, in these, they have near full Manifold Vacuum at Idle. This is ~ OK ~ (manageable) with stock Cams, but when anything with as much as a slight lump at Idle is fitted, the Manifold Vacuum is up and down at Idle, so giving more and less Advance, which will change the Idle Speed and likely a by a fair bit.
2 Solutions that I can think of;- 1 - (the easy) is to disconnect it and block it at the Carb, or 2 - (and what I usually do), is to block off the stock port and fit a new one so that when the Butterfly is in the Idle position, the port is aligned with the edge of the butterfly, that will give next to no vacuum at idle on that port.
Posted 03 October 2018 - 09:00 AM
Ah, OK.
I see, i was just reading your other thread that was talking about that. Is it okay to run the car with the vacuum advance port blocked off? would I lose anything with it like that? i wouldn't mine modifying it in the future, i just don't want to drive it around with the advance blocked if its bad for the engine
Posted 03 October 2018 - 10:00 AM
You only have significant manifold vacuum when the engine's throttled. Running without vac will affect fuel economy, but won't do any damage.
Suppose it'd be possible to rig up a valve to close just before you hit maximum depression, but it'd be simpler just to drill a new hole.
Posted 03 October 2018 - 04:38 PM
Posted 03 October 2018 - 04:49 PM
Ac
Posted 03 October 2018 - 04:55 PM
I keep rebuilt ported vacuum HIF44's on on the shelf if you needed one quickly.
Ac
Posted 03 October 2018 - 05:02 PM
Ac
Posted 03 October 2018 - 06:14 PM
The new drilling g is positioned such that at idle it is covered. Opening the throttle any amount uncover s the drilling g such that it is vented to manifold vacuum.
Ac
Following on with AC's info here, from the top, this is where I position the new port, you can see it next to the original one
These next few shots are of a HS4, but as far as this Port goes, it's the same on a HIF44
Inside, it needs to end up at here - Butterfly Closed (Idle Position and covered - nothing to see)
Just off the closed position
