98 Cooper Sportspack Spots/driving Lamps
10 replies to this topic
#1 leepol83
leepol83
  • 1,744 posts
Posted 27 September 2018 - 05:48 AM
Hi chaps I’ve currently no spots or driving lights on my cooper but want to put them back on once purchased, I’m unsure in the configuration I.e driving lights and spots do the spots go on the outside and driving in side ? I’m having 4, also how do these wire up do the driving lamps come on with the headlamps and are they connected to the flashers, maybe a wiring diagram or wire colour identifier would help me, thanks guys appreciate it
Lee
#2 Bat
Bat
  • 903 posts
Posted 27 September 2018 - 05:53 AM
Hi,
I read recently on here that the 2 inners are fogs, which would be switched by the front fog light switch and the outers are spots which would come on with the main beam. Memory withstanding!  O_O
Cheers  :proud:
Edited by Bat, 27 September 2018 - 05:56 AM.
#3 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 27 September 2018 - 06:46 AM
Outers are fog, inners are main beam. Make sure you get the glass lenses correct too.
#4 Swift_General
Swift_General
  • 871 posts
Posted 27 September 2018 - 07:27 AM
Yep outers fog, inners spots. If you're not using the original wiring, I would personally wire them such that the spots come on with main beam, but can be switched off on their own switch if required, and the fogs need sidelights (and turning on of front fog light switch) to operate. That way you could run with dipped beam off and fogs on if that was deemed to be advantageous.
#5 panky
panky
  • 1,790 posts
Posted 27 September 2018 - 09:45 AM
I wired mine in through a couple of relays. The spots have a signal wire from the main beam and the fogs have a signal wire from the rear fog lamp switch, both sets are switched so they can be turned off if required.
Fogs are on the outside spots in the middle.
Edited by panky, 27 September 2018 - 09:47 AM.
#6 Bat
Bat
  • 903 posts
Posted 27 September 2018 - 02:39 PM
Hi,
I thought fogs on the outside made more sense after idI typed it but my memory told me it was the other way!  O_O
Cheers  :proud:
#7 gazza82
gazza82
  • 3,012 posts
  • Local Club: TMF+
Posted 27 September 2018 - 03:14 PM
You can be very popular if you get it the wrong way around! :-)
#8 leepol83
leepol83
  • 1,744 posts
Posted 27 September 2018 - 05:39 PM
Brilliant thank you all, I’ve exposed the wiring from behind the front panel now so I’ll take some pictures tomorrow see if you guys can help me to wire them up ?
#9 mk1leg
mk1leg
  • 9,343 posts
Posted 27 September 2018 - 07:13 PM
when ever I have fitted spot and fog lights the inner were fog
#10 leepol83
leepol83
  • 1,744 posts
Posted 27 September 2018 - 07:28 PM
I’ve found some 5/12” chrome front driving lamps by wipac on eBay s6007 is the part number on them, can anyone tell me a part number for matching fog lamps ? Also is 5/12” the right size for cooper spec?
#11 Cooperman
  • 23,276 posts
Posted 28 September 2018 - 10:32 AM
To be honest, the spot/fog lights as fitted as standard on the later cars were poor in terms of lighting improvement and were not good quality units. They don't increase the range of the lights much, if at all.
A better option can be to fit a pair of good auxiliary driving lights such as the Cibie Oscar which have longer range. For appearance, the old Lucas 7" 'Flamethrower' (SLR700) was superb when fitted with a halogen bulb, but they are expensive these days.
