Hi, Can anyone advise after replacing scuttle panel, Is it legal to re-stamp Vin (if finding correct stamps) back into panel or best leaving blank?
Thanks, Mike.
Posted 21 September 2018 - 07:47 PM
Thanks, Mike.
Posted 21 September 2018 - 08:05 PM
it is up to you. some people weld the old number bit into the new panel. others dont do anything. but use an old style VIN plate just take pictures and also maybe have a chat with your MOT station as they will be wanting to see the VIN for the test and what would they see as acceptable.
Posted 22 September 2018 - 05:20 AM
Posted 22 September 2018 - 07:31 PM
When it is necessary to replace the front scuttle panel on the later cars which have a VIN stamped into the scuttle panel flange, there are 3 options:
1. Cut the old VIN number out of the rusty panel, cut the new panel and weld the old number in, then linish back the welds and paint.
2. Stamp a new number into the scuttle using a stamp set.
3. leave the new panel with no VIN number stamped and just retain the stamped plate VIN.
Nowhere is it determined which is correct. I asked a Mini-enthusiast ex-police Inspector and he said that any of the above will be acceptable. Even the DVLA can't give a definitive answer. The idea of a VIN plate being to define the origin of a body-shell, and then having the VIN number 'grafted' in from who-knows-where seems a bit incongruous.
Personally I wouldn't bother with the stamped-in number. In this scenario it is pretty meaningless. No MoT tester will be interested anyway so long as the stamped plate is rivetted on.
Posted 25 September 2018 - 08:13 AM
I'm in the same position. I've had a look at the VIN stamping tool from eBay, but none inlude the odd star shapped stamp at the front/end of the vin
(This is from Ben_O's thread)
http://www.theminifo...mini/?p=3489865
Q
