hi guys,
I've got a mk3 mini 1000 in Australia (1972) and there's lots of bits missing including the ignition switch. can anyone point me in the direction of a new switch? they seem hard to find. thanks
Posted 13 September 2018 - 08:35 AM
hi guys,
Posted 13 September 2018 - 10:31 AM
Posted 13 September 2018 - 10:35 AM
Posted 13 September 2018 - 11:12 AM
Searh:
Ignition barrel, where do I start.
Can't work out how to do a link
http://www.theminifo...ere-do-i-start/
Posted 14 September 2018 - 03:05 AM
Thanks guys, Its going to be hard and expensive to get an original I think. If only I'd bought an Aussie mini I'd have less of a headache. I was thinking maybe a switch from something else might fit, has anyone tried it?
Some possibilities:
Morgan https://www.ebay.com...ys/263933511438
MG https://www.ebay.com...W-/381568950524
https://rimmerbros.com/Item--i-BHM7144X
RR Classic https://www.ebay.co....5.c100013.m1986
I reckon either RRC or MG would work fine with some mods to the clamping diameter. Thoughts?
Posted 14 September 2018 - 06:37 AM
Hi,
Do you need just the switch or the lock and barrel as well?
Posted 04 October 2018 - 05:31 AM
Hi All,
I had a little win and have some good info for anyone looking to replace their NLA Early MK3 switch. I spent 12 hrs solid at work looking on the net for possible other switches that would fit, I eventually settled on this MGB switch, I took a gamble and bought it and it turned up yesterday and fits well, haven't tried the cowl on it yet but it should fit. It's a Neiman switch and looks pretty similar to the mini one, not that I had one to compare it to.
https://www.google.c...538714208416688
There are other mgb switches which look the same but appear to fit a larger diameter steering column, this particular one is the only one I found with the smaller diameter and it fits the mini. The part number is ADU 3341
Posted 04 October 2018 - 05:35 AM
hi guys,
I'm pretty sure I have one of these, not sure how I ended up with it, but it's junk to me (as in it fits nothing I have or will ever likely have). Drop me a PM if you like.
