Bluetooth Obd Module And Torque App (Code Reader)
17 replies to this topic
#1 Bat
Bat
  • 903 posts
Posted 11 September 2018 - 06:27 AM
Hi,
For those that don't know anything about this it's basically a Bluetooth dongle that plugs into the cars obd diagnostic port, the one by the steering column.
You then use the app on your phone or tablet and it can read and erase fault codes.
I've used it on BMWs and Vauxhalls.
Any one tried it on a Mini?
***If you're near Walsall, West Midlands I've got it set up but no MPI to plug it into if you'd like to try it out, for free!***
Cheers  :proud:
Attached File  Screenshot_2018-09-11-07-12-04-521.jpeg   35.56K   3 downloads
Attached File  Screenshot_2018-09-11-07-12-58-747.jpeg   34.51K   2 downloads
#2 Ethel
  • 25,919 posts
Posted 11 September 2018 - 08:29 AM
I don't think Mems was OBD compliant.
Often thought there'd be a market for something, even if it read the sensors in tandem - wouldn't help with resets and readings logs tho'.
#3 Bat
Bat
  • 903 posts
Posted 11 September 2018 - 08:33 AM
Hi,
I thought the rules were if it had the plug it had to comply to the obd standard?
There's a bare minimum standard for information to be available at the port for access by a code reader, this is below the amount available with dealer level equipment.
Cheers  :proud:
#4 Bat
Bat
  • 903 posts
Posted 11 September 2018 - 08:35 AM
Hi,
The torque pro app clears codes and logs with gps too.
Cheers  :proud:
Edited by Bat, 11 September 2018 - 08:36 AM.
#5 Ethel
  • 25,919 posts
Posted 11 September 2018 - 08:37 AM
There is, but Mems predates that regulation AFAIK
#6 Bat
Bat
  • 903 posts
Posted 11 September 2018 - 08:45 AM
Hi,
You could be right, this is why I've requested a test subject.
Failing that anyone willing to invest £10 to see if it does work...
Cheers  :proud:
#7 Ethel
  • 25,919 posts
Posted 11 September 2018 - 08:51 AM
http://www.theminifo...iffing-mems-2j/
http://memsdiag.blog...emsdiag-is.html
No idea how they relate, if at all.
#8 Ethel
  • 25,919 posts
Posted 11 September 2018 - 09:14 AM
#9 Wiggy
Wiggy
  • 1,036 posts
Posted 15 September 2018 - 08:13 AM
If no other OBD reader works; why would this one work?
#10 Bat
Bat
  • 903 posts
Posted 15 September 2018 - 12:02 PM
Hi,
I don't know if it will or if it won't hence why wanting to test it.
Cheers  :proud:
#11 Wiggy
Wiggy
  • 1,036 posts
Posted 16 September 2018 - 11:01 PM
Well the app is for OBD standard vehicles. Rover MEMS is not OBD. The method of transmitting the data is fairly irrelevant. The software is the key.
#12 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 17 September 2018 - 07:14 PM
MEMS is not OBD compliment. I think the Honda engines Rover used in their cars around that time were though, which are not MEMS.
#13 Sprocket
Sprocket
  • 7,266 posts
Posted 17 September 2018 - 07:19 PM
PS
I have a Bluetooth OBDII dongle and it works great on OBD II vehicles. In fact, we broke down on the island of Jersey on the day of our return in a Vauxhall Insignia, engine wouldn’t rev, produced no power and the temp gauge was of scale high.
Pulled out the dongle plugged it in opened the app on the Samsung tablet and straight away it gave a fault code. Not my car so with no cares reset the code )no idea what it was for) and the engine ran faultlessly all the way home. Car went back and I never told them ?
#14 yeti21586
yeti21586
    He's A Lumberjack And He's OK
  • 3,724 posts
  • Name: Chris
  • Local Club: None
Posted 29 September 2018 - 08:33 AM
PS
What OBD2 dongle and app do you use??
#15 RooBoonix
RooBoonix
  • 1,224 posts
Posted 30 September 2018 - 01:47 PM
I use a cheap dongle off eBay (£2.30 odd) which was shipped from Hong Kong and I have torque pro and piston which work great! Only had 2 cars which it didn't work on but have used it on loads, always keep it in my car
