Additional Engine Stabiliser
8 replies to this topic
#1 Bobbins
Bobbins
  • 1,486 posts
Posted 03 September 2018 - 07:51 PM
Has anyone successfully fitted an additional engine stabiliser to the LH (thermostat) end of a Japanese spec car? I have a 1998 JDM Cooper and there seems to be a minefield of stabilisers that probably won't fit, probably because of the air-con plumbing.
#2 MrBounce
MrBounce
  • 2,643 posts
Posted 04 September 2018 - 07:50 AM
I don't like Ultimate Engine Steadies. I think they're ugly and don't think they're that great. Have you considered the lower engine steadies that mount from the gearbox to the rear of the subframe? I have 2 on the Midas (along with the standard "! up, 1 down" arrangement) - and my engine does NOT move.
http://www.minispare...px|Back to shop
http://www.minispare...ic/MSSK001.aspx
#3 Bobbins
Bobbins
  • 1,486 posts
Posted 04 September 2018 - 09:58 AM
Yes I'd thought about fitting those as well, they're not so expensive and my thoughts are that in the long run they might help protect the driveshaft seals as well. Back in the 80's the crude way of stabilising the engine was to mount a couple of lengths of steel between the front outside cylinder head studs and the front panel, anchored to the front panel using exhaust bobbins! In retrospect and with a little more engineering care that comes with age it probably wasn't an ideal solution although it did work! The current variety of engine top stabilisers look much more engineered but finding one that I know will work with all the extra stuff under the bonnet of a JDM model is proving difficult.
#4 yeti21586
yeti21586
    He's A Lumberjack And He's OK
  • 3,724 posts
  • Name: Chris
  • Local Club: None
Posted 04 September 2018 - 10:03 AM
Have you looked at the dsn classic stuffs, they're thermostat engine steadys are really good
YetI
#5 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 04 September 2018 - 11:47 AM
The moss one is good. It looks stock and you can barely see it. Not sure about air con pipes though. Fits on the water pump.
https://www.moss-eur...kit-abr024.html
Edited by HUBBA.HUBBA, 04 September 2018 - 11:48 AM.
#6 nicklouse
  • 18,577 posts
Posted 04 September 2018 - 12:01 PM
ugggg putting load into the end of the water pump bolts. will cause more issues than fix.
sorry just poor design.
#7 nicklouse
  • 18,577 posts
Posted 04 September 2018 - 12:04 PM
DSN do a spacer to allow their normal 1275 one to fit the SPI ask them if they have had one on a JDM mini.
#8 Bobbins
Bobbins
  • 1,486 posts
Posted 04 September 2018 - 12:51 PM
Thanks, I will. I've been working with Dave on another part for the interior so need to give him a call anyway.
#9 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 04 September 2018 - 06:11 PM
I've got it on my mini. Been on there since 2009. 120horses. Had no problems.
