Thanks for the info, aside from being possibly a bit quieter is there any reason to fit one of these? It does seem like a solution to a non existent problem - a modification for modifications sake.
I gotta say, I've not found the Duplex Chains at all noisy, or none that I've noticed.
I think Carbon has covered most of it. They do also hold the Cam Timing quite 'tight' and accurate for a long time, but when they go out, they do so with no warning and in a huge way (belt breakage !).
I have a few of these, none that are permanently fitted these days though. There is one set that I did fit often but only temporarily to various engines that has a removable peg and will allow for timing changes in 1 degree increments. I use this to do final settings on various engine configurations to fine tune the cam timing to suit that particular engine, as it's very easy to access and change, without going through boxes of gaskets and making a mess. After settling on a particular Cam Timing, I then swap back to a Chain Drive.
Overall, I agree with your comment though - " It's a solution to a non-existent problem "
