Hif44 Suddenly Runs Extremely Rich
17 replies to this topic
#1 CharlesK
CharlesK
  • 59 posts
Posted 30 August 2018 - 01:15 PM
Hello everyone,
My mini is playing up (again >_< ). It's a 1988 red hot with a 1275 metro engine with a HIF44 carb. After having driven fine for a long time, suddenly the car started sputtering and stalling. I've replaced the plugs (which were completely black). and the car fired up perfectly however, when revving, the sputtering starts again right away and the car stalls. The car also starts shortly after starting without any revving.
The problem must be inside the HIF44 carb but I am unsure what to check. I hope you guys can point me in the right direction. Would a carb refub kit be necessary or should I first check the carb to find the problem? (Dashpot has been topped up, so this is not the issue)
Regards,
#2 nicklouse
  • 18,574 posts
Posted 30 August 2018 - 01:30 PM
I would open it up and have a look. most likely something gummed up. a clean should be sufficient.
#3 Jamdog
Jamdog
  • 50 posts
  • Local Club: 998
Posted 30 August 2018 - 04:42 PM
You can get a service kit for about £30, but probably don’t need it, just take it apart and blast everything with a can of carb cleaner
#4 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 30 August 2018 - 06:50 PM
If you're going to the effort of removing and stripping it, it would be daft to not rebuild it with a proper overhaul kit. If it's not been done before the seals will be well past their best.
Phil.
#5 pete l
pete l
  • 1,368 posts
Posted 31 August 2018 - 09:06 AM
I had this on a metro, it was the choke seal that was leaking. As though the choke was always on, didn't do it all the time. A new little o ring seal fixed it.
#6 mini13
mini13
  • 3,810 posts
Posted 31 August 2018 - 02:53 PM
Yeah, I was gonna say choke seals too.
#7 CharlesK
CharlesK
  • 59 posts
Posted 21 September 2018 - 02:53 PM
I've cleaned the carb by soaking it in carb cleaner for 24 hours. Took off the pot, and float chamber components first.  Took it out and blew it dry using compressed air. Put it back on and still the same problem. I did not dissasemble the throttle or choke linkage. Choke seals sounds plausible but I'm not sure where the seals are located.
Regards,
#8 mini13
mini13
  • 3,810 posts
Posted 21 September 2018 - 03:11 PM
The choke assy comes out and the seals are on it, it's a rotating barrel with holes in so when it rotates it let's the extra fuel in on choke... If the seals are iffy it'll randomly piss extra fuel through.
#9 tmsmini
tmsmini
  • 728 posts
  • Local Club: MOASF
Posted 21 September 2018 - 03:33 PM
Burlen has pretty good documentation on their site:
http://sucarb.co.uk/...ter-dismantling
Somewhere in the parts sections are very good exploded view photographs.
#10 CharlesK
CharlesK
  • 59 posts
Posted 21 September 2018 - 07:11 PM
Thanks, I had a look and the inner rubber was perished. I've replaced it for a new one. I'll post before and after pictures when I get to a computer.
Fingers crossed this fixes it. Trying it tomorrow
#11 CharlesK
CharlesK
  • 59 posts
Posted 21 September 2018 - 10:49 PM
I'll update tomorrow if it works.
Edited by CharlesK, 21 September 2018 - 10:50 PM.
#12 CharlesK
CharlesK
  • 59 posts
Posted 22 September 2018 - 10:24 AM
Ok, tried it out this morning. Now works a lot better, doesn't seem to flood and die anymore. It does run a little rough in higher rpm but I've only driven it down the road 500m. I'll try a longer drive where it'll warm up properly in a bit!
Thanks for the help everyone.
If someone is in need of the rubber choke seals (without the whole gasket set stuff) I could send them in a letter as I have loads of those sizes now. Just send me a pm
EDIT
Just went for another drive and it didn't even make it out of the street. Had to push it back. Seems to be the same issue as before. The car revved smoothly with the clutch disengaged but with the clutch engaged, it was stuttering and losing power until it died.
Edited by CharlesK, 22 September 2018 - 11:37 AM.
#13 mini13
mini13
  • 3,810 posts
Posted 22 September 2018 - 01:47 PM
I'd look at the float valve, it could be worn and letting by, or could be getting debris in it. Also worth adding an in line filter
#14 CharlesK
CharlesK
  • 59 posts
Posted 19 October 2018 - 11:14 AM
I've been trying to figure out why it's not working and it turns out the rubber rings I've used to replace the broken one dissolve in petrol! they become soft and brittle when soaked in fuel! I went out to buy other rings and these seem to stay together however the fit is very tight. This means the rubber ring frays on the choke hole it passes on the way into the shaft letting fuel bypass the choke mechanism once again. Not sure what the fix could be now. Are the rings in a carb refurb kit special?
#15 nicklouse
  • 18,574 posts
Posted 19 October 2018 - 11:38 AM
well they are designed for the job. ones from your local hardware store will not be suitable.
http://www.minispare...hif44.aspx|Back to search
