Nightfire Red Mini Cooper Mpi
21 replies to this topic
#16 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 10 February 2019 - 12:14 AM
Steve does a great work, highly recommend him for any restoration!
#17 jamesmpi
jamesmpi
  • 1,940 posts
Posted 10 February 2019 - 03:55 PM
Wow looking great. ?? I really hope mine isn’t that bad
#18 RT2002MCS
RT2002MCS
  • 18 posts
Posted 10 February 2019 - 04:08 PM
Very nice.
#19 bdean
bdean
  • Just Joined
  • 102 posts
Posted 28 February 2019 - 08:25 AM
Cylinder head back from Calver Special Tuning.
wpTzcU5l.jpg?1
Still a long list a things to get sorted before it can all be put back together.
#20 Cabriomin
Cabriomin
  • 44 posts
Posted 20 March 2019 - 04:27 PM
Looks really good, do you know if the shell needed bracing before removing the complete floor? I cant see any in the pics.
I'm looking to do the same with my Volcano 1997 Cooper soon, are you able\willing to share any costs to give a very ballpark idea that I can work to?
#21 bdean
bdean
  • Just Joined
  • 102 posts
Posted 22 October 2019 - 10:15 AM
So things are slowly moving along. I have all of the wiring looms back and re-fitted. I am trying to keep most stuff original but decided to upgrade the switches and get some USB sockets fitted. Switch panel by David at WiredbyWilson. He also tested, repaired and re-wrapped all of the looms.
I got the gearbox back from Guessworks. I had my old box re-built and upgraded with a X-Pin Diff and changed the final drive to a 3.2.
I had the engine rebuilt at a local specialist (I supplied all of the parts).
Block bored +20
Bungs and cores removed and replaced (the smaller bungs were changed to threaded bungs)
Black faced
Main Centre Cap machine to accept MED strap
New Cam Bearings
Rods balanced
Polished crank journals
Swiftune SW5-07 Cam and Duplex Kit
Swiftune Die Cast Pistions
ARP Con rod and head bolts
Retrosport Timing Cover
Retrosport Thermostat Housing
MED ST1 Clutch Assembly
The only issue the engine builder had was that the pistons were not within the expected weight tolerance but Swiftune sent two replacements so that they were all within tolerance.
My only question is if this engine to gearbox bolt is correct i.e. should the bolt head and washer be above the block?
#22 theclassicminishop
theclassicminishop
  • 22 posts
  • Local Club: MOCSA
Posted 19 February 2020 - 04:39 AM
Good to see this coming together.  Yes that bolt head and washer should be just like that.  That Guessworks puller looks like it can handle anything.
