Bmw K1100 Head Conversion
20 replies to this topic
#1 simplyminis
simplyminis
  • 2,164 posts
  • Local Club: m4minis
Posted 22 August 2018 - 08:37 PM
Ok nearly finished my turbo project and looking onto the next.
Been looking at different engine conversions but keep looking at the k1100 head.
what work is required to carry it out? Head and block work machining?
I have a 1275 and 1293 engine in my garage doing nothing.
grateful for any links or advise on start to finish builds.
#2 WillCarter
WillCarter
  • 523 posts
Posted 22 August 2018 - 08:45 PM
Not too sure about the k1100 conversion but if you've got the funds then the KAD twin cam looks good.
Force racing do K1100 kits, contacting them would probably be a good start on what's involved
http://www.force-rac....uk/contact-us/
Edited by WillCarter, 22 August 2018 - 08:48 PM.
#3 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 22 August 2018 - 09:00 PM
I've just finished a K build. I'd suggest getting the SC build manual. For the sake of £20 it's very useful.
Phil.
#4 KTS
KTS
  • 2,457 posts
Posted 22 August 2018 - 09:18 PM
Phil.
..and i believe that they'll refund the cost of the build guide if you then purchase one of their kits
https://twincammini.com/ documents a conversion reasonably well, plus there's quite a few build threads here as well
#5 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 22 August 2018 - 09:28 PM
DO IT......
#6 gazza82
gazza82
  • 3,018 posts
  • Local Club: TMF+
Posted 22 August 2018 - 10:27 PM
I know someone who has fitted a bmw head to an a-series inline. I can ask for details but pretty sure it involves blocking and redrilling the head bolt holes at least.
Edited by gazza82, 22 August 2018 - 10:28 PM.
#7 simplyminis
simplyminis
  • 2,164 posts
Posted 23 August 2018 - 05:11 AM
Great I’ll buy that for £20
Yeah any help would be great
#8 DeadSquare
DeadSquare
  • 3,177 posts
Posted 23 August 2018 - 08:03 AM
 If you are going to do it yourself rather than buy a kit, you need someone who can weld alluminium and someone with a milling machine.
#9 simplyminis
simplyminis
  • 2,164 posts
Posted 23 August 2018 - 11:41 AM
Yes I have acsesss to all that
#10 DeadSquare
DeadSquare
  • 3,177 posts
Posted 23 August 2018 - 01:18 PM
Buy 10 (4 spare) high tensile 3/8 UNC  2" bolts, with plenty of shank, and with die set as wide as you stock will allow, thread a bolt on down the shank.
If you have one, an old Whitworth die is best, as they cut a more tapering thread.
Having cut the thread on down on the first bolt, cut off all but a couple of the original threads and try it in the block.  It should bind at the third thread, so adjust your stock until it is a tight fit.
If you are engineer enough to have a milling machine, you know what I'm getting at.
Clean the threads in the block in the usual way petrol, jizer, water, meths and screw your re-cut bolts in with Loctite 270.
Use your milling machine, not a pillar drill, to re-drill the block for the re-positioned head studs.
#11 gazza82
gazza82
  • 3,018 posts
  • Local Club: TMF+
Posted 23 August 2018 - 03:17 PM
Checked with him .. he used the SC guide,
#12 Shooter63
Shooter63
  • 1,064 posts
Posted 23 August 2018 - 05:28 PM
I've got the manual and to be honest I didn't think a lot of it, in fact I found better info on the ausmini web site, I've got the head, a short engine etc just need the time to start it. I think there are better ways to do certain things than the book states.
Shooter
#13 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 23 August 2018 - 08:57 PM
Shooter
Agreed. But as a reference and an overview of what's involved I think it's worth the £20.
Phil.
#14 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 23 August 2018 - 09:10 PM
OI think the guide was well worth its 20 pounds, some info is out of date (cam lift for example) and there are many ways to skin a cat.
But for a novice like me the guide was great
#15 scoop-deluxe
scoop-deluxe
  • 63 posts
Posted 24 August 2018 - 10:47 AM
Matt Read here in Australia is highly recommended. He has done heaps of them and sell kits with good instructions. Worth looking in to.
ReadSpeed Mini Mecca & The Mini Man
