Australian Mini Van - Bare Metal Rebuild
43 replies to this topic
#16 Guess Developments
Guess Developments
  • 32 posts
Posted 21 August 2018 - 11:35 AM
Nice van, I saw that for sale a few months ago!
Mini K van, has the 4 syncro remote box. You will need to get floor pans locally as we had a different ribbed section than the Uk floors. The front doors are the only other unique body parts.
Have fun with it!!!
So is there a difference between the 4 syncro and the magic wand box as I was under the impression that my van was a magic wand?
#17 scoop-deluxe
scoop-deluxe
  • 63 posts
Posted 22 August 2018 - 11:44 AM
Check the gearbox casing number. It should be 22g1228 (I think!) That will be 4 syncro casing. There will be a metal plate that bolts to the diff housing that holds the gearstick. It will go through the same hole in floor as a wagic wand shift, but they called it a 'pudding stirrer' instead.
#18 Guess Developments
Guess Developments
  • 32 posts
Posted 22 August 2018 - 09:14 PM
Is there any way to improve the shifting on these magic wand / pudding stirrer boxes if rebuilt properly?
#19 scoop-deluxe
scoop-deluxe
  • 63 posts
Posted 23 August 2018 - 11:03 AM
If rebuilt properly then it should be ok. Depends on what you're expecting out of it, thats all. If you get a remote extension though that will be the best one out of all.
#20 Guess Developments
Guess Developments
  • 32 posts
Posted 23 August 2018 - 07:58 PM
Forgive my ignorance what is a remote extension?
#21 nicklouse
  • 18,583 posts
Posted 23 August 2018 - 09:32 PM
see this thread
http://www.theminifo...1-gear-linkage/
#22 Guess Developments
Guess Developments
  • 32 posts
Posted 24 August 2018 - 07:10 AM
This is great thanks.  I think I will stick with the original configuration and if it is truly shocking then I will look into something like the remote extension.
#23 Guess Developments
Guess Developments
  • 32 posts
Posted 24 August 2018 - 07:12 AM
Time to remove the rusty rear closing panel
#24 Guess Developments
Guess Developments
  • 32 posts
Posted 26 August 2018 - 10:44 AM
I just ordered a few new panels....
Rear step
Beaver Panel
LH Beaver
RH Beaver
Beaver closing panel
LH lower 1/4 repair panel
RH lower 1/4 repair panel
This should keep me busy for a while!
#25 SAL 821X
SAL 821X
  • 1,890 posts
Posted 29 August 2018 - 06:33 AM
Nice looking project.
I had a mk3 850cc saloon in that colour.
#26 Guess Developments
Guess Developments
  • 32 posts
Posted 30 August 2018 - 08:11 PM
I have been toying with the idea of going all black
#27 scoop-deluxe
scoop-deluxe
  • 63 posts
Posted 31 August 2018 - 10:00 PM
It will always be dirty, even after you wash it!!!
Did you order the panels local or from the Uk? I just got a quote for freight from a Uk supplier for some panels and the price was horrendous. Having to rethink now...
#28 Guess Developments
Guess Developments
  • 32 posts
Posted 02 September 2018 - 01:48 AM
I ordered the panels through Lincoln @ Aus Mini Spares.  I want to try and keep everything as local as possible.  I will probably order the 7 Port head direct from Pierce Manifolds in USA though.
I own a Black Land Rover at the moment, and my last one was too - intact my last 3 motorbikes were black come to think of it so I know the down falls well, they just look so good!
#29 Guess Developments
Guess Developments
  • 32 posts
Posted 06 September 2018 - 11:39 PM
What are peoples thoughts on putting a pierce Manifolds 7 port onto the 1100 motor with a 040' over bore.
running twin webers 38 / 40 doce
#30 scoop-deluxe
scoop-deluxe
  • 63 posts
Posted 07 September 2018 - 11:28 PM
My initial thoughts are its a fair bit of time and money for a gain that wouldn't be much. The room in a round nose is not as much as a clubman so its a tight fit. A mate of mine put one in his GT, absolutely hammers but its a 1340. He had to spend heaps on the head as there were a lot of issues with spring heights etc.
Personally I would spend the money modifying your existing head, matching it with a suitable cam and choose whatever intake that takes your fancy. Just my opinion!!
