Bl Special Tuning Cams
25 replies to this topic
#16 72r1mini
72r1mini
  • 57 posts
Posted 07 August 2018 - 11:24 PM
In order to make the best of my current set up with the 731 cam, would it be recommended to use the 1.5 forged rockers?
If this will optimize my potential I can plan for a cam swap in the future
#17 nicklouse
  • 18,638 posts
Posted 08 August 2018 - 12:18 AM
do you have the clearance for the 1.5s? are you happy with the increased wear?
just get some standard pressed rockers as mentioned before.
#18 72r1mini
72r1mini
  • 57 posts
Posted 08 August 2018 - 01:41 AM
I wouldn't be able to verify how much clearance I would have with out splitting. I have no idea how much was taken off the head or block etc.
Thanks for all the valuable info,
Its greatly appreciated
#19 nicklouse
  • 18,638 posts
Posted 08 August 2018 - 01:50 AM
and here is the crux of the issue without splitting and measuring  you are really stuck with just keeping it as it is.
#20 Dusky
Dusky
  • 5,322 posts
Posted 08 August 2018 - 06:13 AM
Surely could make something to test this.
Need a dti, and something to compress the spring/valve.
#21 DeadSquare
DeadSquare
  • 3,136 posts
Posted 08 August 2018 - 06:44 AM
Make a 1/4" loop in the end if a piece of fine curved wire.
Roll a 1/4" plasticine 'rod' and push it through the loop.
Squash it so that the wire grips it, and it is the right size to fit through the spark plug hole and cool it so that it is fairly firm.
With the piston 1/2 way up the exhaust stroke, position the plasticine under the exhaust valve and get the crank turned through a further 180 degrees.
Remove the plastercine and measure it.  If the plastercine doesn't come out through the plug hole, repeat with reshaped plastercine.
Ditto the other three cylinders.
PS  Using something harder than plasticine, and taking great care, valves can be "held" while changing valve springs.
#22 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 08 August 2018 - 09:12 AM
That's keyhole surgery DS !!
Not sure how practical it actually is....has anyone ever done it  ??
I would not want the potential for leaving a lump of placticine in combustion chamber[s]
A boroscope would let you see it but it would still be a guess.
I use an adaptor on a DTi for TDC through a plug hole
So thinking about it....if you get the exhaust to full lift [with a DTi on it]  some how lever the rocker down till the valve stops on the top of the block and bingo a measurement.
Check the valve spring is not fully compressed.
The difficult bit will be levering the rocker down.
#23 nicklouse
  • 18,638 posts
Posted 08 August 2018 - 10:35 AM
mmm block to valve could be the issue not valve to piston.
#24 DeadSquare
DeadSquare
  • 3,136 posts
Posted 08 August 2018 - 11:02 AM
I used to fit cams for motor club friends, usually a 948 in an 850 or maybe a 731 in an 1100, without worry as the increase in valve lift is only 50 thou, but one day a chap rolled up, told me about his twin Webber and shaved head etc: and asked if I'd to fit his new cam.
It looked lumpy, and something made me wonder, so I got out the dial gauge.
4 bits of bent wire and plasticine  proved to him that evening, why I wouldn't do it for him.
#25 62S
62S
  • 1,243 posts
  • Local Club: You must be joking!
Posted 09 August 2018 - 11:12 AM
If you do change the cam in situ you'll need a replacement with the same oil pump drive which will restrict the choice; should be a pin drive if an original BL ST 731.
#26 Cooperman
  • 23,309 posts
Posted 09 August 2018 - 05:11 PM
For what you might gain, higher lift rockers are really  not worth the risk.
Higher ratio rockers may give you a bit more top-end power, but with a 731 cam you will lose some bottom-end torque. That sounds like a poor trade-off for what is a relatively mild cam in an old car for road use. If it were for timed competition it would be different, but in that case you would not be using a 731 cam.
