Sportspack Suspension
23 replies to this topic
#16 nicklouse
  • 18,583 posts
Posted 22 August 2018 - 02:26 PM
Hi
If u need a good suspension first go with springs rather than cones there is one special for rally better than cone. And lower arm adjustable and hi lo adjustable
Regarding the shock absorbers go with these two only:
1) bilstein b4 its gaz
2) koni lowered
I give u these as per my experience on mpi and i will give u photos for my suspension if u want
sorry. springs are totally unsuitable on the Mini. they have a linear rate (not rising) they are positioned incorrectly and create a failing rate suspension design. requiring a stiffer spring than is actually needed so you get a very harsh ride which goes soft in roll.  and don't get me started on the replacement coils. they don't have the required travel. they get coil bound and fail or cause the subframes to fail.
#17 Kubbar
Kubbar
  • Just Joined
  • 82 posts
Posted 22 August 2018 - 03:05 PM
Hi
Is i know there are 3 types of spring soft and std and hard which is using for rally and minispares selling it
Maybe u r special in rally and u r more experience for that
But if u would like to change the suspension u have to change the arm and tge shock to get best results
Regards
#18 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 22 August 2018 - 03:20 PM
Noob logic.
#19 gazza82
gazza82
  • 3,014 posts
  • Local Club: TMF+
Posted 22 August 2018 - 03:21 PM
"Poke the bear" ....
... and wait ... ;D
Edited by gazza82, 22 August 2018 - 03:21 PM.
#20 nicklouse
  • 18,583 posts
Posted 22 August 2018 - 09:38 PM
Hi
Regards
three types mmmm so you are taking about the direct replacement ones. first off anything will feel better than an old sagged rubber doughnut.
first what happens to these coil springs before they reach full suspension travel
so what happens when the springs go and bind (no air between the coils)
or maybe you have blue ones
or some red ones?
 nice.
so as well as needing to be stiffer ( fatter coils) they just do not have the required travel to work correctly.
#21 Kubbar
Kubbar
  • Just Joined
  • 82 posts
Posted 22 August 2018 - 09:47 PM
Oh my god! The spring and the subframe damaged
This was very bad. I did not know that it was bad for travel. The cones will be sure better thanks for sharing ur acknowledge
Reagrds
#22 CityEPete
CityEPete
  • 3,920 posts
Posted 23 August 2018 - 09:15 AM
Springs, oversills and polyBush front subframe to toe board mountings should be banned from sale.
#23 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 23 August 2018 - 10:10 AM
Hi
Regards
Thing is the rubber cone is a rising rate device which means the more compressed the cone the more load it will take. However springs don't help
#24 Kubbar
Kubbar
  • Just Joined
  • 82 posts
Posted 23 August 2018 - 12:53 PM
Thanks guys for sharing these information i will uploud the photos for my suspension but let me know how to insert photos here
