Rev counter problem
Posted 10 October 2006 - 07:38 PM
The other doesn't seem to have any voltage on it and am unable trace the wiring through the loom.
In the engine bay the rev counter sensor on the engine block has a 12/13v feed to it.
Is my rev counter broken or have i got an electrical problem.. checked all connections and fuses etc.
Need help.
Posted 10 October 2006 - 08:33 PM
Posted 10 October 2006 - 09:43 PM
Posted 11 October 2006 - 12:22 PM
Posted 11 October 2006 - 12:33 PM
you need the right brackets tho. as the standed 2 clocks ones are diffrent to 3 clock ones.
or do you just want to add a stand alone pod rev counter.
Posted 11 October 2006 - 12:49 PM
Posted 11 October 2006 - 04:54 PM
We later discovered there was an electrical problem because the wiper motor park-switch had failed and was causing a short circuit.
So if your wipers have stopped parking themselves or are a bit dodgy, then replace that park-switch because it causes all kinds of electrical mayhem and the same thing happened on my sisters 92' Mini British Open Classic LE too after her wipers stopped parking themselves. But as that didn't have a rev counter, the fuel gauge went haywire. But once the park-switch was replaced everything worked fine again afterwards!
I want the 3 clock setup i had in my old car but just wondered how to go about wiring it up when there isn't one as standard in this.
Well if you have the straight ahead (Clubman style) 2 pod clock in your Mini City (should have if it's a post 1985 model?), then the wiring is already present. You just need to get the extra rev counter bit to add on I believe?
Edited by taffy1967, 11 October 2006 - 04:55 PM.
Posted 12 October 2006 - 07:30 AM
Thats good to know then, just a little less work for once. i'll have a look at the weekend, see if i can see anything lying around.
Posted 16 October 2006 - 06:43 PM
Posted 16 October 2006 - 06:45 PM
