Mini Pick-Up @ Mill Road Garage, Isle Of Wight
pickup
355 replies to this topic
#121 cooperd70
cooperd70
  • 723 posts
Posted 04 January 2019 - 09:48 AM
Like the above comment fantastic work, this pup is really coming together now.
Is this one yours MM?
#122 Baldspeed Racing
Baldspeed Racing
  • 1,191 posts
Posted 04 January 2019 - 10:08 AM
the fab work with top dolla as the norm, always good reading your updates chap
#123 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 04 January 2019 - 11:28 AM
No, It's KTS's
Ben
#124 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 04 January 2019 - 04:53 PM
Quick refit of the drivers door to double check and that's one side done
The gaps are too tight but this will be rectified when I reskin the door.
Next up, the passenger side inner wing was removed
And then a clean up before trial fitting the new inner wing
It seemed to drop nicely into place
I then clamped and screwed the inner and outer A panels on so that I could try the door on.
I wasn't expecting it to be good and It certainly wasn't
The front isn't too sad
But the back......
Not far off of the fit in the photo the owner put up a few pages back.
I had a tweak around and achieved a better gap
Still a long way off but I think there is something else going on here as the wing doesn't want to sit nicely either.
I screwed the step and jamb in to stiffen things up
And had another go
It's starting to even out but it needs to be better so ill have a think over the weekend and go back to it next week
It doesn't help that the door frame is out of shape too which is causing this
But I can address that when reskinning the door.
hmmmmmmm
#125 cooperd70
cooperd70
  • 723 posts
Posted 04 January 2019 - 05:16 PM
love the care taken over ensuring everything offers up really nice after all the bodge jobs that we all hear about. Magic is happening here folks ???
#126 KTS
KTS
  • 2,420 posts
Posted 04 January 2019 - 07:41 PM
Drivers' door is looking really good already. Very pleased with what you've done there Ben
Not sure I want to know how/why the passenger door frame's out of shape, but looking forward to see how you deal with it
Cheers!
#127 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 19 January 2019 - 12:31 PM
Long time no see but beavering has been done.
This corner of the truck has given me major grief.
I managed to get the door aligner to an acceptable standard (which I can perfect later) but the wing just didn't want to sit nicely to the A panel and was under tension when clamped to the A panel which in turn pulled the A post and subsequently the door making the gap to the side panel waayyyyy to large.
So I stopped and stepped away to have a think. I went through what we know:
The door gap was previously all over the place before I started
The door wanted to naturally sit too low at the front
Raising the door height meant that it would clash with the roof frame and upper A post
The windscreen didn't fit well prior to me starting.
But most importantly, someone has been in here before and replaced the lower section of the A post boxing panel so I got to thinking
What if the piece was cut out and the upper A post sagged down? This would explain a lot but as lots of other work has been done too in the past plus me replacing the floor, what else would be wrong?
I decided that the door can only fit in one place to get an acceptable gap to start with, The door is square (ish) and the side panel is square so lets start by squaring the door up in the hole without the restrictions of door hinges or worrying about the position of the A panel yet.
So I did what any sane person would do and welded the door into the hole!
And the jacked up the roof frame to loose the sag
Right, that's not going anywhere
Wing on
Looking good
Tweaking required here
Much better gaps now and although wider than the other side, they are pretty even so I can work with that once I reskin the doors
Most Importantly, no tension anywhere so I call that a success.
Inner wing off and prepped before spot welding the inner A panel to it
Car prepped
I gave the window frame a tweak
And built the front back up again
Still fine so ready to weld in
Before I weld the inner wing on, I really want to build up the A post so I partially welded the inner wing in a few places and added a few screws to keep everything in place.
And the removed the welds from the door to check that it will stay where I want it
It has although as I previously said, the gaps are a little wide. I'm confident that everything is now in the right place at last so I can address the finer details later.
Off with the outer A panel and on with the step
Then a few screws and try the door on again
There is a slight sag in the middle but as the step is rigid due to the folds, I am blaming the door and will address that with a new skin
Then I welded on the step
Mocked up the jamb
And then welded that in
And finally made up a new boxing panel
And we are up to date.
Next, ill finish up the A post area and then get the front end on
Ben
#128 KTS
KTS
  • 2,420 posts
Posted 19 January 2019 - 12:46 PM
Bravo Ben !!
#129 Grant 111
Grant 111
  • 18 posts
Posted 19 January 2019 - 01:05 PM
Really impressive, Your skill is really showing on this one keep up the good work.
#130 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 19 January 2019 - 01:40 PM
Cheers guys.
#131 JXC Mini GT
JXC Mini GT
  • 841 posts
Posted 19 January 2019 - 01:46 PM
Great work Ben and a masterclass in solving door / panel alignment.
#132 Wiggy
Wiggy
  • 1,036 posts
Posted 19 January 2019 - 02:25 PM
Inspiring stuff! You're a real credit to your industry.
#133 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 21 January 2019 - 12:58 PM
Lunchtime update.
Boxing plate in
door jamb to upper door frame finished
Clean up and prep
Build up
Weld
And finished
I needed to trim the step slightly as it was a tad oversized
Done
Now onto the front end.
Ben
#134 KTS
KTS
  • 2,420 posts
Posted 21 January 2019 - 02:12 PM
..after 17 years owning the car i've finally got a passenger door that fits !!!  thanks Ben - great work as always
#135 the.stroker
the.stroker
    TMF Admin
  • 4,348 posts
  • Name: Dan
Posted 21 January 2019 - 02:32 PM
Ben your skills never cease to impress......
Also tagged with one or more of these keywords: pickup
