Mini Pick-Up @ Mill Road Garage, Isle Of Wight
pickup
355 replies to this topic
#316 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 27 June 2019 - 09:49 PM
OK - that sounds good. do you want to mock up some positions that you think might work and we'll go from there ?
Yep, ill sort that tomorrow
Ben
#317 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 28 June 2019 - 03:21 PM
I think I have solved the tank situation
Rivnuts
Trimmed down stand off pegs
Bolts and washers
And up it goes
I put the hinges back together and fitted the doors
I also began fitting the door glass
I suppose I ought to get the running gear cleaned up and painted next.
Ben
#318 KTS
KTS
  • 2,420 posts
Posted 28 June 2019 - 06:29 PM
i really, really like the way this is going  :proud:
nice job on the tank fitting.  looks good.
#319 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 01 July 2019 - 05:15 PM
After de-greasing and stripping the running gear, I cleaned off the rust and prepped them.
Then hung it in the booth and applied etch primer
Then on with 2 coats of the satin matt 2k
Ben
#320 KTS
KTS
  • 2,420 posts
Posted 01 July 2019 - 06:44 PM
thanks Ben - another step closer to getting rid of it  ;D
#321 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 01 July 2019 - 08:23 PM
Hopefully it will be on its wheels tomorrow :-)
#322 KTS
KTS
  • 2,420 posts
Posted 01 July 2019 - 08:37 PM
good stuff.  they'll need some air in them  ;D
hopefully the catches will be with you tomorrow too..
#323 REVVIT
REVVIT
  • 341 posts
Posted 01 July 2019 - 08:38 PM
With or without wheels its looking superb...
#324 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 02 July 2019 - 06:23 PM
Another step closer today.
I have reassembled all of the running gear and fitted it to the car.
Wheels on and onto the ground for the first time in a while
hmmmmm, needs some weight in the front i think...
#325 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Bonus photo
#326 KTS
KTS
  • 2,420 posts
Posted 02 July 2019 - 07:14 PM
thanks Ben
i'd like to say that looks great, but it doesn't; those wheels are shocking.  just as well they won't be staying on it for too long...
i'm going to have to put the headlights in when it some back - something very sad about a mini without headlights...
smart work on the running gear though !
#327 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 02 July 2019 - 08:15 PM
Cheers Pat.
Although the running gear is assembled, I have not torqued up anything on the front as you are going to need to remove the hubs to fit the driveshafts once you have the engine in.
There is also quite a few nuts and bolts that I have cleaned up and reused but would benefit from being replaced if you are so inclined
I will torque up and grease the back end as you only need to fit the brakes there so it won't need to come apart.
I'm going to fit the door seals, glass and steering column tomorrow but I need to do some maintenance work to the workshop in the afternoon which can't be put off any longer.
Ill leave the flat/polish of the paintwork until we have arranged a collection date so that it's all freshly done.
Are you collecting or am I sending it to you?
Ben
#328 KTS
KTS
  • 2,420 posts
Posted 02 July 2019 - 08:34 PM
Hi Ben
that's fine thanks, and don't worry about torquing up the back end - i've a feeling one of the radius arm grease tubes is split (..seemed to take an awful lot of grease  :ohno: ), and as i've managed to get hold of steel ones, i'll be replacing them, and any manky fasteners along the way.
you were sending it back to me, as i recall
one other thing (from when you were doing the GT i think); did you get any chrome side trim for it ?
cheers
Pat
#329 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 02 July 2019 - 08:39 PM
Hi Ben
cheers
Pat
Ok, that's fine. Ill leave it all as is for you then.
I have the chrome side trims ready to go. I have just been waiting to get it rolling as I like to fit them in the spray booth with the heat on so that they go on smoothly without kinking.
I shall probably wait until the polishing is done first though.
Ill get in touch with Mick who picked it up and see what his scheduled is like and then we can get it sorted out for you.
I shall be taking a long awaited holiday on the week beginning 15th July so hope to complete before then.
Ben
#330 KTS
KTS
  • 2,420 posts
Posted 02 July 2019 - 08:43 PM
that's great.  thanks Ben
Also tagged with one or more of these keywords: pickup
