Mini Pick-Up @ Mill Road Garage, Isle Of Wight
pickup
355 replies to this topic
#286 KTS
KTS
  • 2,420 posts
Posted 20 June 2019 - 06:05 PM
wow - that's flying along !!  cheers Ben
subframes have come up really well, and the grille looks good - might have to see if i can find some grey edging instead of the black though
Edited by KTS, 20 June 2019 - 06:58 PM.
#287 wingnut
wingnut
  • 463 posts
Posted 21 June 2019 - 01:25 PM
As always, great work Ben.Do I spy another mini there?
#288 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 21 June 2019 - 01:33 PM
Thanks mate.
yep, that's the next project under the blue cover http://www.theminifo...ge#entry3602669
Ben
#289 SAL 821X
SAL 821X
  • 1,890 posts
Posted 23 June 2019 - 08:00 AM
cracking looking pup Ben.
#290 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 24 June 2019 - 03:19 PM
After some deliberation, I decided to paint the doors in 2 stages.
There really was no way of hanging the doors in such a way where I could paint the outer skin and all inside the open frame of the doors at the same time.
I ended up prepping the doors, sealing up the skin folds and then painting the insides of the doors first. It meant I could get the paint in everywhere without the frames of the panel stands interfering.
All ill need to do now is mask the inner frames up and paint the outer skins next time.
Whilst it was in there, I also painted a few bits and pieces
Forgot to mention or take photos but I replaced the studs in the bonnet hinges too as they were very worn meaning that the nuts wouldn't fully grip once tightened.
All good now :-)
Ben
#291 KTS
KTS
  • 2,420 posts
Posted 24 June 2019 - 03:28 PM
thanks Ben   :thumbsup:
#292 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 25 June 2019 - 01:25 PM
Now that the bonnet lock and hinges are painted, I have fitted the bonnet.
And I have finished painting the doors
I also did the rear lamp shells and the rear hoop tubes
Ben
#293 KTS
KTS
  • 2,420 posts
Posted 25 June 2019 - 01:59 PM
beautiful work as usual Ben.  cheers
#294 CharlieNZ
CharlieNZ
  • 69 posts
Posted 26 June 2019 - 08:18 AM
Must be amazing to own a mini done by Ben, with doors that fit, shut lines that aren't awful, everything lining up and immaculate paint. I can but dream...
#295 cooperd70
cooperd70
  • 723 posts
Posted 26 June 2019 - 11:05 AM
Couldn't have put it better myself ?
#296 Shep76S
Shep76S
  • 543 posts
  • Local Club: L&SMOC
Posted 26 June 2019 - 01:23 PM
Lovely colour!
#297 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 26 June 2019 - 03:58 PM
Little bit more done.
Steering rack in with new gators and track rod ends
Swiftly followed by the sub frame with solid mounts
Before I can fit the doors, I need to do something with the hinges.
I have already re-pinned and bushed them but the surface is very deeply pitted.
Thats one of the better ones. Obviously they are solid so this is purely cosmetic.
I decided to sand back as far as I could which resulted in this
I shall apply 3 coats of highbuild, flat that back and then repeat and that will fill the pitting. Id rather use paint than filler here.
Ben
#298 KTS
KTS
  • 2,420 posts
Posted 26 June 2019 - 04:19 PM
cheers Ben - the hinges had a fair amount of filler in/on them when i took them off.  can't tell you how long it took to extract the remnants of the studs that sheared off (of 16 screws & studs, 6 sheared and i think one i just couldn't get out)
it's going to be a bit strange needing to wear gloves to keep the car rather than my hands clean when i start work on it  O_O
#299 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 26 June 2019 - 05:07 PM
I can imagine they did have lots of filler.
Problem is, you need to be careful that you dont end up with too much material on them, especially at the hinge points to avoid damage when opening the doors.
I think they will come up nicely with some work.
cheers
ben
#300 KTS
KTS
  • 2,420 posts
Posted 26 June 2019 - 05:32 PM
..that pretty much sums up this build doesn't it  ;D
Also tagged with one or more of these keywords: pickup
