Will the new staff make your life easier?
#211
Posted 26 April 2019 - 03:40 PM
#212
Posted 26 April 2019 - 07:44 PM
Sadly not.
The new staff comprise of a receptionist, a mechanic and an apprentice mechanic.
The mechanic is very experienced with classics and keen to work on them too so he will be available to help out with that side of things.
The man from the college that comes to assess the apprentice has mentioned that he has a student in an accident repair centre on the island who is unhappy there so may be interested in coming to work with me but we will see.
If he does and is good, then that will certainly help a lot but sadly, my previous experience with trainees has not been good.
The last one didn't even last a week as he was more interested in skiving off, sitting around, playing with his phone and very little else.
I can't put up with that!
Ben
#213
Posted 27 April 2019 - 07:36 PM
I know the feeling Ben - Feel like my apprentice has absolutely 0 interest in cars and is only there to have a job. What a world we seem to live in Wish we could get a lot more harder working people like yourself!!!
#214
Posted 30 April 2019 - 02:52 PM
On with the primer prep.
I started with the front end sanding the primer on the external panels
And then the engine compartment
And then I started the mammoth task of sealing up all of the seams and joins. I find it best to do this stage in sections so that you can be through and not miss anything..
Next, I shall flat the cab roof, get the gutter sealed up and then get the inside of the cab prepped and sealed.
Once the exterior and interior of the shell is ready, I shall then put it back on the spit so flat, seal and refinish the underside in one go.
Ben
#215
Posted 30 April 2019 - 04:12 PM
I know that a few photos doesn't really reflect the the amount of time and effort that goes in at this stage, but it is appreciated !
#216
Posted 30 April 2019 - 04:52 PM
#217
Posted 30 April 2019 - 05:22 PM
Hi Ben, are you not blending the top of the apex panel to A post, with external door hinge cars you dont see the join at the top of the Apex panel.
I hadn't thought about that.
Any external hinge cars I have done in the past have either not been blended or were but with filler making me think that it shouldn't be.
Ill let Pat decide and go from there.
cheers
Ben
#218
Posted 30 April 2019 - 05:52 PM
Ps: I mighthave a business proposal for mg's... In CH (Swiss)
Ben
Edited by MacGyver, 30 April 2019 - 05:53 PM.
#219
Posted 30 April 2019 - 06:51 PM
#220
Posted 30 April 2019 - 07:03 PM
I hadn't thought about that.Hi Ben, are you not blending the top of the apex panel to A post, with external door hinge cars you dont see the join at the top of the Apex panel.
cheers
Ben
Midridge2 might be on to something there - just spent a bit of time looking at the Betty Richmond trophy race photos, and it looks like they are all blended into the A post.
Hadn't really noticed it before, but it does look neater - your response above suggests filler isn't the way to go, so what options does that leave ?
#221
Posted 30 April 2019 - 07:10 PM
cheers
Ben
I shall weld it across and shape accordingly.
It is a very good point indeed and one I shall add to the old brain box.
Everyday is a school day!
Ben
#222
Posted 30 April 2019 - 07:12 PM
#223
Posted 30 April 2019 - 07:25 PM
They were brazed new from the factory and lead body solder. I am old enough to have worked on them in the 60s.
Thanks for the tip - much appreciated !
#224
Posted 30 April 2019 - 07:49 PM
looks good mate! what seam sealer have you used and have you wiped the back of the inner wings with scotchbrite to get that finish?
thanks ;)))
#225
Posted 30 April 2019 - 11:15 PM
Seam sealer is a wurth one and a majority of the engine compartment was sanded by hand with 400. I used a scotchbrite in the tight areas
Ben
Also tagged with one or more of these keywords: pickup
Projects →
Mini Variants →
Mini Pickup Body PartStarted by MikesMiniPickup , 19 Aug 2022 ![]() |
Projects →
Mini Variants →
South African Mini 'bakkie'Started by Jared Mk3 , 04 Jan 2020 ![]() |
Projects →
Mini Variants →
'81 PickupStarted by KTS , 15 Apr 2019 ![]() |
Projects →
Mini Variants →
Scot In SwitzerlandStarted by ings , 15 May 2018 ![]() |
pickup
Projects →
Mini Variants →
Project Penny - Complete Restauration Including TimelapseStarted by Rasmus Holst , 29 Dec 2017 ![]() |
