Mini Pick-Up @ Mill Road Garage, Isle Of Wight
pickup
355 replies to this topic
#1 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 30 July 2018 - 05:05 PM
So the next one is underway!
It's a 79/80 Pick-up and looks reasonably good at first glance but is still going to require a lot of work to bring it back up to scratch.
It has had a fair amount of work done in the past like most including a new front end but overall is very solid.
I'm going to be replacing the front end including the scuttle and A panels (inner and outer) Ill replace the entire cab floor including sills, cross member and heel board and then there are just many small repairs and some slightly larger ones.
Once done, it will be re-painted in this colour again.
Ill be sending it off for blasting so I want to remove the front end to make it easier for the guy to do a through job.
First to come off are the wings and front panel
And then I can start removing the remains of the wing tops, scuttle and A panels. Not wonderfully easy as they have been replaced before so lots of plug welds to discover and grind out.
I had planned to repair the inner wings but I'm not sure what they are going to be like post blasting so ill have to wait and see.
To remove the A panels, I need to locate and grind out the plug welds.
That's as far as I have got so far but stay tuned for further updates on this one.
Ben
#2 fiestaharry
fiestaharry
  • 295 posts
Posted 30 July 2018 - 05:19 PM
Wow, cant wait for this one, love the attention to detail!
#3 Vinay-RS
Vinay-RS
  • 2,115 posts
Posted 30 July 2018 - 05:34 PM
What's the plan for this one? Will it be going back to stock or will it keep the arches and stuff?
#4 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 30 July 2018 - 06:12 PM
The finer details haven't been discussed fully yet.
Ill get the main bulk done and then see what the customer wants to do.
#5 Carlos W
Carlos W
  • 10,114 posts
Posted 30 July 2018 - 06:14 PM
I've been looking forward to this one
#6 FlyingScot
FlyingScot
  • 2,664 posts
Posted 30 July 2018 - 08:01 PM
Nice one Ben very interested in this as a PUP owner
FS
#7 KTS
KTS
  • 2,420 posts
Posted 30 July 2018 - 09:12 PM
Oh my word - that’s a bit scary, but is good to see it’s restore finally starting after a decade on SORN
Back to stock(ish) - it’ll have its commercial grille reinstated, but removable to make my life easier (..but not Bens, as he’s got to fabricate it!), arches and 12” rims are going in favour of 10” steels. MG Metro lump that came out of it will have a freshen up and go back in.
#8 domdee
domdee
    Formally known as dominicdee
  • 1,183 posts
Posted 30 July 2018 - 09:25 PM
Tundra Green  :wub:  :wub:  :wub:
#9 CAU998
CAU998
  • 1,202 posts
  • Local Club: TMF South Central...
Posted 31 July 2018 - 09:29 AM
Sounds like yet another awesome build by Ben.
Spec sounds spot on, very tasteful. Look forward to further updates KTS!
#10 Carlos W
Carlos W
  • 10,114 posts
Posted 31 July 2018 - 11:18 AM
Take a shock mount off. I’m sure that’ll be decision made about the inner wings
#11 KTS
KTS
  • 2,420 posts
Posted 31 July 2018 - 11:28 AM
could be, but I don't think it's 'earthy' enough. I've asked Ben to colour match it, so hopefully he'll be able to provide a definitive answer
Yep - another opportunity for Ben to show how it's done, and maybe provide some guidance and a bit motivation for some of the other pickup projects out there
#12 KTS
KTS
  • 2,420 posts
Posted 31 July 2018 - 11:37 AM
I don't think that's really necessary - I suspect they'll fall off at the first gentle waft of the blasters gun..
#13 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 31 July 2018 - 05:14 PM
Ha ha, the area behind the shock mounts are the best part of the inner wings!
#14 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 31 July 2018 - 05:31 PM
Continuing on from yesterday, I got the o/s outer a panel off
And then the inner
All went fairly smoothly but has made light of some repairs that will be necessary to the A post.
I think it's fairly obvious now that the best course of action is going to be replacing the inner wings entirely especially as once the repair times are deducted and replaced with replacement times, the difference in price is nominal but I am yet to discuss this with the owner.
I repeated the same the other side
And that is the front end off
Next, the front subframe came out
And the steering rack and column
Then onto the rear sub frame
Tailboard
And we are about there
The subframes are going to be blasted too so they were stripped
No after pic but it's in the background on this pic
And then we carried it back into it's spot
All ready to go of to Martin at MJG so the only updates now will be anything I receive from him.
Mick is going to collect the shell and parts on Friday morning and take it over there. There is a 2-3 week turnaround so ill get some panels sorted out in the meantime.
Ben
#15 KTS
KTS
  • 2,420 posts
Posted 31 July 2018 - 07:47 PM
Cheers Ben - let's see what the blaster uncovers. I'm sure it'll be fine
Also tagged with one or more of these keywords: pickup
    Google (1)
