1970 Morris Mini K
#76
Posted 30 August 2021 - 09:00 AM
#77
Posted 11 October 2021 - 10:31 AM
Where would be the best place to purchase the panels from?
#78
Posted 12 October 2021 - 11:12 AM
I removed the bitumen on my car with a hot air gun and scrubbed them away.
For the panels I ordered at M-Machine, they have decent quality panels, some are Heritage, some self made and also a few from Magnum if I remember well.
A bit of progress is still good, mine is on hold at the moment... Not enough time to get to my father's shed and dig the shell out...
#79
Posted 13 October 2021 - 08:38 PM
#80
Posted 13 March 2022 - 09:41 PM
A few more hours after being neglected were spent yesterday. I have almost finished grinding back the driver's side floor when I discovered some dodgy, well I won't say repairs, because even with my knowledge filling rust holes with body filler isn't a repair, to the driver's side sill. Just behind the jacking point there is a fair amount of rust. The rest of the sill looks good so I think I cut it out and replace it with metal and not body filler.
I've painted the bare metal with a high zinc paint as we have almost daily rain here after flooding twice in 6 weeks, so that the car won't rust any more.
I also cut out what was left of the battery box so that I can get my grinder in to remove the rest of the bitumen paint and road grime from underneath the boot floor. There I discovered more dodgy repair with a replacement wheel well put in but not finished off properly underneath. I'll take a photo of that later and see if I can get some advice on the best move forward with that.
#81
Posted 14 March 2022 - 09:48 AM
Edited by sonscar, 14 March 2022 - 09:49 AM.
#82
Posted 14 March 2022 - 12:06 PM
It looks like the sill has been replaced with a folded piece of sheet metal, as there are no flutes visible.
#83
Posted 14 March 2022 - 09:09 PM
Colin, seeing what the rest of the “repair” work is like I wouldn’t be surprised. There is one flute on the sill at the back but that’s it.
#84
Posted 14 March 2022 - 11:06 PM
#85
Posted 15 March 2022 - 12:26 AM
My June 1970 K has only a single flute to the rear on each sill.
Paul.
#86
Posted 15 March 2022 - 12:15 PM
Good spot Timmy
I don't think I would have noticed that at the time of doing my aussie Leyland Mini...
Edited by colinf1, 15 March 2022 - 12:16 PM.
#87
Posted 16 March 2022 - 07:06 AM
If that’s the case with my sills then I’ll look at repairing the driver’s side. Either that or wait until I prep the passenger’s side before ordering replacement panels.
#88
Posted 20 April 2022 - 12:47 PM
Spent a bit more time on the mini shell yesterday. It seems as though the previous person that worked on the mini loved bitumen paint to cover up rust. It looks like I'm in for a new boot floor as the rust section has about 4 different angles to it and the wheel well is a flat piece of steel that has had a few cuts in around the edges and welded into place.
#89
Posted 18 September 2022 - 01:24 AM
Received a box full of goodies from Minispares last week. New boot floor, rear valance front floor pans to replace the "repaired" panels fitted to the vehicle. I managed to get some time to break out the trusty grinder and wire wheel inside the front wheel well. And as usual found more rust. This time there was a combination of body filler and bitumen paint so that I guess the last bloke must have started at the front and made his way backwards as there was more care taken to fill the rust.
#90
Posted 27 January 2023 - 02:36 AM
Well after a few months I managed some time in the garage again. As usual found more “repaired” rust. I’m very close to the point where I can cut out the flat steel floor panels. My question is since I only need to replace the floor pan and not the inner or outer sills do I need to add bracing in the door opening when I cut the floor pan out?
