1970 Morris Mini K
120 replies to this topic
#46 70K1100
70K1100
    Formally Known as NOT850
  • 222 posts
Posted 30 November 2019 - 10:57 AM
It was weird because the passenger side head light trim was in perfect condition.   But there was no panel on the vehicle to use as a starting point.   Very sad.
#47 70K1100
70K1100
  • 222 posts
Posted 05 December 2019 - 02:51 AM
Can anyone tell me what the minimum height the mini shell has to be off the ground from level in order to get full rotation when on a rotisserie. I'm about to start to build one and I have limited height in which to work on my mini. I have about 1.8m in height in my work space
#48 jamesquintin
jamesquintin
  • 1,017 posts
Posted 05 December 2019 - 09:20 AM
I don't know of the top of m head, but I'd say measure from the center to the corner of the roof (at 90deg to the center line) which should give you the minumim.
When Mine was on the spit the floor was probably 30cm off the ground?
Q
#49 70K1100
70K1100
  • 222 posts
Posted 06 December 2019 - 01:51 AM
Thanks James I’ll measure that up today.
#50 70K1100
70K1100
  • 222 posts
Posted 05 May 2020 - 07:50 AM
What have people done for an aerial? I am thinking about filing in the hole on the passenger side guard. Plus what rebushing kit do you use to rebush the boot lid hinges? Are they the same as the door pin kit for the mk1 minis?
#51 70K1100
70K1100
  • 222 posts
Posted 22 May 2020 - 04:50 AM
I’ve managed to pick up a Cooper S airbox recently. Does anyone have a picture of a surf blue Cooper S engine bay so I can see what it looks like? Despite my internet searches I can’t find any pictures.
Edited by 70K1100, 22 May 2020 - 04:51 AM.
#52 mercenary62
mercenary62
  • 359 posts
  • Local Club: mini clan
Posted 22 May 2020 - 08:49 AM
#53 70K1100
70K1100
  • 222 posts
Posted 22 May 2020 - 11:34 PM
Thanks mercenary.
#54 70K1100
70K1100
  • 222 posts
Posted 14 August 2020 - 09:06 PM
I bought a set of stainless steel wheel nuts for my ROH Contessa wheel a while ago and found them the other day.   I trial fitted them on one of my wheels and they fitted without any hassles which was great to see.
#55 70K1100
70K1100
  • 222 posts
Posted 21 August 2020 - 07:43 AM
Does anyone know how long the screws are for the cooper s airbox. DSN classics have two different lengths 18mm and 27mm?
#56 70K1100
70K1100
  • 222 posts
Posted 27 October 2020 - 10:51 AM
Looking back and I really haven’t done much with mini in a while. Latest update is I have received a shipment from Minispares but haven’t had the chance to unbox it yet.   I will reveal it when I start some holidays in about a month during than time I am hoping to get the rotisserie finished and start the task of sanding down the floor.   I’ve narrowed down the mini to two paint colours: Smoke grey and Surf blue. I never thought that it would be so hard deciding on a colour. I dragged out the rear subframe and was looking at hitting it with a wire wheel, now thinking that sandblasting would be a better option.   What do people think?
#57 70K1100
70K1100
  • 222 posts
Posted 19 December 2020 - 01:17 PM
I collected the subframe from being sandblasted. It looks like I’ll need to do some panel beating to tidy it up a bit. My biggest concern is the rust in the two dimpled sections.
Now do these section need to be there or can I just weld in a flat section of steel instead?
#58 70K1100
70K1100
  • 222 posts
Posted 22 December 2020 - 07:47 AM
Got an hour in the workshop today. Made a start on the rotisserie but ran out of supplies.
#59 70K1100
70K1100
  • 222 posts
Posted 04 January 2021 - 03:00 PM
I received my wheels, Hs2 carburetors and manifold back from vapour blasting.   I'm quite happy with the results.   Next project is to figure out how to secure the carb bodies onto my drill press so that I can drill them out to rebush the bodies prior to rekitting them.
#60 70K1100
70K1100
  • 222 posts
Posted 20 April 2021 - 06:32 AM
I’m putting together a new order through minispares and before I complete it I have a couple of questions that I’m hoping someone on here can help me with. First is it worth spending the extra money putting the larger 1.04” exhaust valves in a 295 or are the standard ones good enough. Secondly, I’ve purchased a couple of HIF SU carbs which were advertised as HIF6. Now are the rebuild kits for these the same as the HIF44 ones?
Thanks.
