1970 Morris Mini K
122 replies to this topic
#1 70K1100
70K1100
    Formally Known as NOT850
  • 224 posts
Posted 24 July 2018 - 07:29 AM
I have been a member on this forum for a few years and have had my Mini K shell for even longer.   I bought the shell after seeing it advertise on the side of the road.   After a deal made the shell has been sitting under my house ever since.   Until I heard about the Rylestone Classic and decided that I better get my but into gear and make a start on the mini to hopefully one day make it to the rally.
The good.   Well being fortunate living in Australia the shell only has a little bit of rust in the A panels and top of the driver's side guard.
The bad.   Whoever had the mini before me decided that running a roof mounted wing was a good idea.   No photos thankfully but four holes to weld up in the roof.   The roof also has a hole cut for a sunroof, thankfully the car came with the sunroof but wouldn't have been my choice to do.   I remember when I lived in the UK I had a Mini City E with a white sunroof which looked very similar to the black one that I have now so that maybe an option in the future.
Plans are to rebuild the shell with all wheel drums and a warm 1098.   I have a 295 head and a 202 head with the peaks in between the valves ground away with plans for a 266 type camshaft and twin HS2s.
Colour is an ever changing decision.   Lately it has been switching between Surf Blue, Almond Green and Smoke Grey.   The only common theme is the white roof.
Hopefully this build log will keep the motivation up to get the mini finished over the next few years.
Cheers.
#2 70K1100
70K1100
  • 224 posts
Posted 24 July 2018 - 07:39 AM
I bought a set of ROH Contessa wheels of ebay a while ago.   I think the previous owner had a thing for BMW judging by the colours of the wheels.
#3 Vinay-RS
Vinay-RS
  • 2,115 posts
Posted 24 July 2018 - 08:30 AM
I like those wheels. They're something different. Good luck with the restoration of your Mini.
#4 70K1100
70K1100
  • 224 posts
Posted 24 July 2018 - 08:55 AM
Thanks Vinay.
#5 70K1100
70K1100
  • 224 posts
Posted 10 August 2018 - 08:57 AM
I managed to get a few hours in the workshop over the last few days.   I took the 3 synchro gearbox off my engine and swapped it for a rod change gearbox that I will strip down at a later date.   However looking at the crank I observed some what appears to be machining marks.   Can anyone tell me if these are just factory machining marks of signs of crank balancing?
I bought a while ago what was listed as a lightened flywheel and backing plate.   Putting the two backing plates together I noticed a significant difference between the two.   Is the one on the right alright to be used as the weight is quite noticeable.
As well as this I observed some holes drilled into the backing plate as well.   Again can anyone tell me if they could be signs of balancing?
#6 johnR
johnR
  • 2,297 posts
Posted 10 August 2018 - 12:07 PM
The cluster of holes drilled in the backing plate will more than likely be for balancing - but you'll need all the components you use (crank, damper & flywheel) checked individually for balance and balanced together ideally.
#7 70K1100
70K1100
  • 224 posts
Posted 10 August 2018 - 11:26 PM
Would the lightened backing plate be right to be used? To me it looks like the outer surface has been cut away.
#8 Bat
Bat
  • 903 posts
Posted 11 August 2018 - 04:45 PM
Hi,
That looks like a great backing plate, there should be a mark on one leg to like it up to the flywheel to maintain the balance of the assembly.
Cheers  :proud:
#9 70K1100
70K1100
  • 224 posts
Posted 12 August 2018 - 05:58 AM
Thanks Bat.   I was wondering after I took the backing plate and flywheel off my engine how to put it back together so that the balance was not affected.
#10 70K1100
70K1100
  • 224 posts
Posted 12 August 2018 - 06:17 AM
Can anyone tell me the difference between these two flywheels?   The one on the bottom came off my small bore engine.   Is there a difference between large and small bore engines?   I've noticed that the one on the bottom has bolts that surround the hole where the crank goes through and the other one doesn't.
#11 Daz1968
Daz1968
  • 2,058 posts
Posted 12 August 2018 - 01:47 PM
The 2 piece one is just earlier, they should interchange ok, only different flywheels dimensionally are ones for the very early thin tail cranks. Although later 1300 flywheels are very heavy with a ring around the outside.
#12 70K1100
70K1100
  • 224 posts
Posted 13 August 2018 - 08:17 AM
Thanks Daz. The top one is a lightened one I bought with the backing plate. I hoping that the smaller amount of weight with a more modern cam should liven the engine up a little. Plus hoping that the head in the picture posted earlier should flow a lot better.
#13 70K1100
70K1100
  • 224 posts
Posted 04 September 2018 - 04:51 AM
I scraped together some time to work on my mini today. After watch the classic mini DIY channel on YouTube I managed to remove the rear sub frame from the car. Next step is to finish off my rotisserie and spin the car around to start the horrible task of stripping the underseal.
#14 70K1100
70K1100
  • 224 posts
Posted 19 September 2018 - 12:45 PM
Box of goodies arrived today for the mini.   Now I just need the time to start putting the front and rear subframes together and finish off my rotissorie.
#15 70K1100
70K1100
  • 224 posts
Posted 01 October 2018 - 06:15 AM
Managed over the weekend to get some time on the mini.   I have started to take bits and pieces out of my minispares box and started to put things together again.   Never really thought that this moment would actually happen.   I typed up a to do list just to get the car back on it's wheels.   Almost a full A4 page of tasks.   Looked good when at the end of the day to have crossed a couple of things off that list.
