Shocks: Standard Vs Lowered
12 replies to this topic
#1 NunoTT
NunoTT
  • 64 posts
Posted 23 July 2018 - 02:31 PM
Hi!
I've been looking to buy a set of Hi-Los and shocks for the Mini, but I've reached an impasse... Standard height or lowered?
I don't plan on having the Mini slammed to the ground, I'm hopping to have a two, to three finger gap between the top of the tyre and the body (I'm runnig 165/70 R10 Yokos), so what shocks do should I get?
Also, I was thinking of getting GAZ shocks. Are they any good?
Thanks in advance!
NunoTT
#2 Milton
Milton
  • 54 posts
  • Local Club: what no brakes
Posted 23 July 2018 - 02:41 PM
Two to three fingers normal shocks are fine. Gaz are ok, but, even on the lowest setting they are harder than the standard shocks. Have them on mine and I have zero setting on the rear and 6 clicks on the front.
#3 nicklouse
  • 18,577 posts
Posted 23 July 2018 - 03:16 PM
the difference in heights can be seen here https://www.calverst...damper-lengths/
#4 racingbob
racingbob
  • 3,061 posts
Posted 23 July 2018 - 03:38 PM
lowered protech on mine didn't like the gaz
#5 Alice Dooper
Alice Dooper
  • 391 posts
  • Local Club: Minis in Northern Ireland
Posted 23 July 2018 - 05:24 PM
I have minitastic fast road springs, so fitted GAZ lowered dampers. They help stop the springs unseating if I ever go airborne!!
We like the GAZ and have them set about 3 clicks on the back and 4 on the front. They’re great with the springs.
#6 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 23 July 2018 - 06:50 PM
Fit rubber cones, not springs if using the car on the road.
For dampers use Protech as they'll be softer than Gaz
Edited by cal844, 23 July 2018 - 06:52 PM.
#7 NunoTT
NunoTT
  • 64 posts
Posted 23 July 2018 - 07:19 PM
Thanks for the settings!
Thank you SOOOO much! I have no idea how much time I spent looking for something like that
Why? To hard?
With rubber cones I don't have the problem of them unseating right?
I will use rubber cones. I'll most likely use the MiniSpared "Red Dot"
#8 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 23 July 2018 - 08:18 PM
Why? To hard?
Minispares red spot are the cones I'd recommend. You are correct that the springs can cause the trumpet to part company with the spring
#9 Orange-Phantom
Orange-Phantom
  • 614 posts
Posted 23 July 2018 - 09:16 PM
Another one here giving the thumbs up for Minispares Red spot cones and Protech Dampers.
I pulled the springs off mine and am very very glad I did.  It's like a whole new car and that's an understatement!!!  The fact that you can have springs unseating tells you something as well!  You'll also need a lot more damping for springs too.  The rubber cones have a natural damping ability hence the need for softer shocks.
#10 Orange-Phantom
Orange-Phantom
  • 614 posts
Posted 23 July 2018 - 09:20 PM
Just out of curiosity, what settings are you using on your dampers?  I don't think I'm far off on mine after switching back to rubber cones but would be nice to compare / try someone else's settings.
P.S. I hope your feeling better and are on the mend fella!
#11 racingbob
racingbob
  • 3,061 posts
Posted 24 July 2018 - 10:41 AM
got my protect on 6 but I got them upgraded if not would be on 9 out of 12 I bought these new but we're 8 years old and had slight leak so took them to protech and he put new seals in and upgraded them
#12 Readers14
Readers14
  • 439 posts
Posted 24 July 2018 - 11:46 AM
I've just recently fitted Protech standard height dampers, as the previous Spax ones were shot.
Standard rubber cones & trumpets too.
Got the Protechs on the softest setting at the moment but going to gradually click them up until I'm happy.
#13 andyapanel
andyapanel
  • 623 posts
Posted 25 July 2018 - 11:46 AM
I believe Minis are near enough to the ground without further lowering-unless you really want to increase your risk of damage,but I am just an old fogey!
Its your car, do what you want-that's what minis are all about isn't it? Good luck, whichever route you go down.
