Spark Plug Gaps
happydude2012
, Jul 21 2018 01:12 PM
18 replies to this topic
#16
Posted 22 July 2018 - 08:57 PM
Well I have been using feeler gauges to set plug gaps since 1959 and have never had any issues.
#17
Posted 22 July 2018 - 11:08 PM
what ignition was you using. yes those the plugs I tried bit had no go to it brisk said for better ignition carsThe difference in hp was negligible , 2 HP if I recall right. Torque curve was a lot smoother,and higher from low rpm.what was the difference on the mini in hp and what brisk do you use. the cone lookìng brisk I tried coil couldnt cope and drove like 998The mini was VS ngk plugs, the mustang was VS AC DELCO plugsdid you compare to ngk plugs on dynoI run no gap, i only run brisk multispark plugs (a true multispark plug,not a 3 electrode plug) after seeing the dyno result on my own cars. Worth their price imho.
Dr14zc if I recall right, I should take a look in my paperwork,its a few years ago now
The powerspark ignition module with the sports coil on the mini, new leads etc as well. Indeed need a very good ignition system for it!
#18
Posted 23 July 2018 - 08:44 AM
Also they are called feeler gauges because you can feel when the gap is correct!
#19
Posted 23 July 2018 - 09:02 AM
what ignition did you mini run for those plugs. mine was Lucas electronic not powerful enough had no go to it ok on my mates mpi tho said good
The powerspark ignition module with the sports coil on the mini, new leads etc as well. Indeed need a very good ignition system for it!what ignition was you using. yes those the plugs I tried bit had no go to it brisk said for better ignition carsThe difference in hp was negligible , 2 HP if I recall right. Torque curve was a lot smoother,and higher from low rpm.what was the difference on the mini in hp and what brisk do you use. the cone lookìng brisk I tried coil couldnt cope and drove like 998The mini was VS ngk plugs, the mustang was VS AC DELCO plugsdid you compare to ngk plugs on dynoI run no gap, i only run brisk multispark plugs (a true multispark plug,not a 3 electrode plug) after seeing the dyno result on my own cars. Worth their price imho.
