Spark Plug Gaps
18 replies to this topic
#1 happydude2012
happydude2012
  • 332 posts
Posted 21 July 2018 - 01:12 PM
Bonjour la class
quick musing on spark plug gaps
is setting the gap a definite have to, if so does anyone have a link to a useful resource? lots of trashy "I reckon" stuff online but some idea of what to do and why from a "hexpurt" would be very valuable.
thanks
#2 Cooperman
  • 23,276 posts
Posted 21 July 2018 - 01:56 PM
Set spark plug gaps to an accurate 0.025". It's a 'must do'.
#3 andyapanel
andyapanel
  • 623 posts
Posted 21 July 2018 - 02:04 PM
Haynes has all relevant info.
#4 happydude2012
happydude2012
  • 332 posts
Posted 21 July 2018 - 02:44 PM
silly question, can i use my valve clearance feeler for this or do i need the swanky spark plug end bending tool thing? if there even is such a thing?
also, what type of spark plug do you reccommend?
#5 Dusky
Dusky
  • 5,322 posts
Posted 21 July 2018 - 02:51 PM
I run no gap, i only run brisk multispark plugs (a true multispark plug,not a 3 electrode plug) after seeing the dyno result on my own cars. Worth their price imho.
#6 gazza82
gazza82
  • 3,012 posts
  • Local Club: TMF+
Normal feeler gauge is fine. You should need to bend them often. Unless you drop it and ram it closed! (Oops!)
Tapping gently closes them
#7 mini13
mini13
  • 3,810 posts
Posted 21 July 2018 - 03:05 PM
if your completly without anything to measure them, the thickness of a hacksaw blade is not far off.
#8 racingbob
racingbob
  • 3,061 posts
did you compare to ngk plugs on dyno
#9 Ethel
  • 25,919 posts
Posted 21 July 2018 - 07:18 PM
The bigger the gap the stronger the spark - assuming your ignition is up to the job. 25thou is the figure for points, electronic ignition might manage up to 40thou but 32thou is in Rover's books.
#10 Dusky
Dusky
  • 5,322 posts
Posted 22 July 2018 - 12:28 PM
The mini was VS ngk plugs, the mustang was VS AC DELCO plugs
#11 racingbob
racingbob
  • 3,061 posts
Posted 22 July 2018 - 02:25 PM
what was the difference on the mini in hp and what brisk do you use. the cone lookìng brisk I tried coil couldnt cope and drove like 998
#12 Dusky
Dusky
  • 5,322 posts
Posted 22 July 2018 - 05:56 PM
The difference in hp was negligible , 2 HP if I recall right. Torque curve was a lot smoother,and higher from low rpm.
Dr14zc if I recall right, I should take a look in my paperwork,its a few years ago now
#13 racingbob
racingbob
  • 3,061 posts
Posted 22 July 2018 - 06:19 PM
what ignition was you using. yes those the plugs I tried bit had no go to it brisk said for better ignition cars
Edited by racingbob, 22 July 2018 - 06:23 PM.
#14 A-Cell
A-Cell
  • 1,610 posts
Posted 22 July 2018 - 07:24 PM
The flame spread from the kernel (initial igniting of fuel air mixture) from these multi spark plugs is unlikely to be suited to the A series head as this was developed using single j type electrode.
The standard cylinder head was designed and developed to use the single electrode (old fashioned) plug.
Gap of 0.025 inch for contact distributor, 0.032 inch for electronic ignition.
If the gap is too small then there will be less air/fuel between to be ignited, too large a gap and the spark will be weak and ignition of the mixture poor and late.
So as Cooperman said correct gap is very important.
It only takes a few extra minutes to correctly gap plugs before fitting.
#15 spin
spin
  • Just Joined
  • 56 posts
Posted 22 July 2018 - 08:52 PM
A wire gauge  not a feeler gauge was the standard when leaded fuels were used
& plugs were cleaned and gaped more often.  you will not get a correct gap
on a worn plug with a feeler only with a wire gauge.
One of the wire types courtesy of Halfords
Attached File  gap gauge.tiff   143.64K   43 downloads
