Distributer Shaft Install
Posted 19 July 2018 - 09:21 PM
Need some advice/tips and a wee bit more confidence. I have done this once but not at tbc . I had to take the dizzy and the connecting shaft to the oil pump? Out and struggling to get it back in. I can get it to within 5cm then it just seems to not want to go any further. 1275 a+ engine.
Secondly will i ever lose the shaft inside the engine if i have a clumsy monent?
Thanks in advance
Posted 19 July 2018 - 09:56 PM
sounds like you are hitting the crank. you just have to allow it to move past. just make sure the stud you have in the end dont unscrew and you will be ok.
Posted 19 July 2018 - 10:11 PM
There is a threaded hole in the centre of the drive spindle that takes a 5/16unf bolt. Usually a long bolt from the left hand engine mounting bracket or even the lower radiator mounting bracket bolt makes it very easy to install the spindle in the correct orientation.
Edited by Sprocket, 19 July 2018 - 10:12 PM.
Posted 19 July 2018 - 10:50 PM
How to remove & install dizzy drive gear
on an MGB the A series eng. is the same.
This one Eng in the car again on an MGB
More difficult than than the MIni.
Edited by spin, 19 July 2018 - 11:22 PM.
Posted 20 July 2018 - 03:59 AM
Posted 20 July 2018 - 04:30 AM
Posted 20 July 2018 - 04:35 AM
Posted 20 July 2018 - 05:49 AM
Posted 20 July 2018 - 08:20 AM
Posted 20 July 2018 - 08:49 AM
same thread in both. you can use the same whatever you have to hand to install it. generally the longer the better.
Posted 20 July 2018 - 07:23 PM
Posted 21 July 2018 - 06:50 AM
Posted 21 July 2018 - 08:35 AM
I have this picture on my phone just to remind me when refitting or adjusting the spindle.
I also have a photo of the Haynes page describing how to find tdc for static timing as well.
Edited by whistler, 21 July 2018 - 11:32 AM.
Posted 21 July 2018 - 08:44 AM
Posted 22 July 2022 - 08:43 PM
Just seeking clarification. As long as the dizzy rotor and cable to no 1 position at TDC are aligned then all is well. Mine points to around 4 o’clock rather than 1.
