Custom Clubman Bonnet
15 replies to this topic
#1 Chris.Williams
Chris.Williams
  • 679 posts
Posted 16 July 2018 - 12:38 AM
So I fitted my engine, complete with supercharger over the weekend.
Bonnet won’t close, fouls on the carb.
Anyone had an issue like this?
I’m thinking of changing my bonnet to this
http://www.absmotors...ax-mini-bonnet/
Anybody got one, seen one in person???
Any other thoughts and opinions are more then welcome.
Chris
#2 Geehawk
Geehawk
  • 500 posts
Posted 16 July 2018 - 07:42 AM
My opinion ... that bulge does not suit the Clubman shape bonnet at all.
Can you not just raise the rear of the Clubman bonnet to gain enough clearance? Would look far better than the bulge IMO.
Edited by Geehawk, 16 July 2018 - 07:47 AM.
#3 Chris.Williams
Chris.Williams
  • 679 posts
Posted 16 July 2018 - 08:07 AM
I find the raised rear just makes the bonnet look like it doesn’t fit haha..... It might grow on me though, I’d need to look up some more pictures. Is that your clubby?
Edited by Chris.Williams, 16 July 2018 - 08:07 AM.
#4 mpialan
mpialan
  • 116 posts
Posted 16 July 2018 - 11:07 AM
How bad is the foul between carb and underside of the bonnet? Would removing the strengthening web on the underside of the bonnet give you enough clearance? If yes, you could always weld some sort of extra stiffening in to give the bonnet a bit more strength, once the web is removed.
#5 Chris.Williams
Chris.Williams
  • 679 posts
Posted 16 July 2018 - 11:24 AM
Strengthening web runs from the rear corner at the centre of the front, not an issue there.
Attached File  8CB559C3-96DE-4C4A-A9B5-235632327C17.jpeg   152.68K   5 downloads
You can see in this picture where the carb is in relation to the front scuttle panel, and the bonnet hits on the carb wingnut, leaving a good size gap at the front of the bonnet. ( about half an inch gap )
Edited by Chris.Williams, 16 July 2018 - 11:24 AM.
#6 nicklouse
  • 18,400 posts
Posted 16 July 2018 - 12:26 PM
change the wing nut to a normal one? then see what the gap is like.
#7 Geehawk
Geehawk
  • 500 posts
Posted 16 July 2018 - 01:07 PM
http://www.absmotors...p-carbon-fibre/
Yes my Clubman.
Would an ERA style vent suit. I used to have one and it fitted the clubman bonnet fine, not sure if it would be in the right location for your carb nut though.
#8 Chris.Williams
Chris.Williams
  • 679 posts
Posted 16 July 2018 - 07:21 PM
Yes my Clubman.
I love ya clubman, checked out your build page, very thorough.
Well yes I did look at these, I think it might be worth a measure up, I was just unsure if the bonnet ridge would suit, but you confirm its a go.
I'll look into it.
#9 Chris.Williams
Chris.Williams
  • 679 posts
Posted 16 July 2018 - 07:24 PM
Did think of this, but when I saw the gap at the front of the bonnet I realised that would be pointless.
If I get a chance I'll throw the bonnet on and grab some pictures up through the grill.
#10 nicklouse
  • 18,400 posts
Posted 16 July 2018 - 08:02 PM
why? as it is so close to the hinges a small change there will make a big change at the front.
#11 timmy850
timmy850
  • 3,222 posts
  • Local Club: MITG
Posted 18 July 2018 - 10:58 AM
Here are some photos of the Zeemax bonnet on a car
http://minisport.com...-scoopa-clubman
#12 Shukran
Shukran
  • 129 posts
Posted 28 July 2018 - 06:07 AM
NOOOOO that Zeemax bonnet is hideous.
#13 pinkmini99
pinkmini99
  • 563 posts
Posted 29 July 2018 - 07:40 AM
Chris
Is this the vmaxscart kit ? If so it states on there webpage no bonnet or bulkhead modifications are needed.
So in my eyes something is not righ some where.
#14 Chris.Williams
Chris.Williams
  • 679 posts
Posted 29 July 2018 - 08:18 AM
Yes, I’ve come to agree.....going to get the ERA bonnet scoop.
Will work well
#15 Chris.Williams
Chris.Williams
  • 679 posts
Posted 29 July 2018 - 08:21 AM
Chris
Yes it’s the vmaxscart kit.
I was under that understanding also. I’m wondering if it’s the fact that the 1275 engine is slightly taller, add to that the decompression plate thickness.....lots to consider
