Hi all
Removed my sump plug to replace with a new one and they are completely different.
I thought there was only 1 type.
Any ideas
Posted 09 July 2018 - 11:39 AM
Hi all
Any ideas
Posted 09 July 2018 - 11:42 AM
looks like PO stripped the original thread and fitted something else.
Posted 09 July 2018 - 11:55 AM
Posted 09 July 2018 - 12:42 PM
i don't think you've got much choice unless/until you want to replace the gearbox casing
helicoils *might* be an option, but there's such a big difference between the two plug threads it looks unlikely (..to my untrained eye)
Posted 09 July 2018 - 12:51 PM
Posted 09 July 2018 - 01:25 PM
Posted 09 July 2018 - 03:15 PM
Looks like its bodged to me to be honest
Iv got a sump plug repair kit your more than welcome to use Steve, Im doing nowt with it. I did a sort of how to when I did mine :)
Can drop it off sometime over the next week for you, or you can pick it up from mine ...
Posted 09 July 2018 - 04:12 PM
Posted 09 July 2018 - 05:32 PM
It involves making the sump hole bigger, then a tap is ran through the hole to cut a thread then a sump plug of the desired size is inserted....
I'll look for the guide i did last year...
Posted 09 July 2018 - 05:50 PM
I think it maybe a bodge but it doesn’t seem to leak. Well it didn’t before I took it out. What does the sump plug repair kit entail. Will it still work since the hole seems a lot bigger than the correct sump plug? The car is still being built so it isn’t driveable but the engine is in. I’ve just had a quick search for your guide but couldn’t see it. I’m sure I use the search facility wrong. I often look for things and can’t find and then someone puts the link up.
Here you go Ste ;)
http://www.theminifo...30-sump-repair/
Hope it helps..
Posted 09 July 2018 - 07:19 PM
Posted 09 July 2018 - 07:30 PM
I came across one on a Gearbox I've just built up. Of course the condition of the thread was looked at at the time of it being a bare case and it looked perfect.
Only, when it came time to fit the Plug, I was coff coff over the moon to find out it was tapped to M18, which I think might be too close to the original 5/8" to make a sensible insert for.
I'll likely find a decent M18 proper sump plug from something else and fit a magnet to it.
Posted 09 July 2018 - 07:39 PM
loads out there already but they tend to be for gearbox.
eg
http://www.burtonpow...5-rs-ap-05.html
Posted 09 July 2018 - 08:53 PM
eg
Cheers for that - saved me looking !
<Edit: Bummer. The thread I have is M18 x 2.5. All the sump plugs I've looked at (so far) are M18 x 1.5 ! This just keeps getting better,,,,>
Edited by Moke Spider, 09 July 2018 - 09:22 PM.
Posted 09 July 2018 - 10:25 PM
It does have a good thread inside the casing and like I say it wasn’t leaking.No need for a helicoil as it appears to have a good thread already. A timesert could sleeve it back to the stock plug,bit why would you go through the effort?
