After taking the steering cowling off the back end of the ignition barrel was hanging off. I believe I gathered up all the parts.
does anyone have an assembly picture of the parts as shown in attached photo
Posted 07 July 2018 - 10:46 AM
Posted 09 July 2018 - 12:41 AM
There is at least one part missing...there should be a cover over the gubbins and probably 3 ball bearings
I've been doing Minis since 1979 and have never seen inside one
You will be very lucky to find an assembly image as its not a component normally rebuilt.
They are also NLA so it either rebulid it or 2nd hand
Posted 09 July 2018 - 10:50 AM
Posted 09 July 2018 - 01:12 PM
Posted 09 July 2018 - 07:39 PM
Sounds easy but the MK3 pre 76 lock and switch is NLA
And if its a true Mk3 the lock is the awkward 90 degree one which was only fitted 5 or 6 years.
It would be easier to swap to a later columb, cowl and lock
Posted 10 July 2018 - 08:02 AM
Posted 10 July 2018 - 09:24 AM
....Just found out that the switch is a lucas 39683e ignition switch....
Where did you get that number from?
So many websites, so much conflicting information! I tend to use Somerfords, it's generally more accurate http://www.somerford...page=page&id=86
Mk3 would have been fitted with either a Magnatex or a Lowe & Fletcher ignition steering lock, both had the same part number 18G8892!
The Magnatex ('safety' lock) is marked Neiman-tex 01 13H7565-6 & the switch is 37H6544 (yours isn't that one).
Can't remember the number on the Lowe & Fletcher steering lock but the switch is 37H6962
https://www.ebay.co....6kAAOxyzHxRSOai
Fit a later column & lock to a Mk3 ....You should be burnt as heretics
Edited by Itsaminithing, 10 July 2018 - 09:32 AM.
Posted 10 July 2018 - 09:11 PM
I got the number from the side of the switch... I have contacted a few places and they say that they are no longer available... I really don't want to fit a younger steering lock assy... it is running but I don't have the key return spring fitted so have to start it then turn back a click once started... will look out for a second hand column with lock and just rip the switch off it
Posted 10 July 2018 - 10:54 PM
I've already given you all the info you need.
You have a Lowe & Fletcher Mk3 ignition steering lock (check the number on the main body, it will be 13H6966/7)
The switch is marked 39683e, the actual part number is 37H6962.
My comment about burning heretics was for anyone suggesting fitting a Mk4 lock instead of the correct MK3 (there isn't a younger steering lock assy, they only came in with the Mk3).
Posted 11 July 2018 - 04:46 AM
Thanks for your reply.. I have managed to put it back together less the key return spring as I couldn't work. That bit out. Just found out that the switch is a lucas 39683e ignition switch. Which is unavailable. Trying to. Hunt down a replacement
Posted 11 July 2018 - 10:05 PM
is this the same on ebay
273350362791
273350362791
Posted 12 July 2018 - 07:19 AM
Doesn't look like a mk3 to meis this the same on ebay
273350362791
273350362791
Posted 12 July 2018 - 08:33 AM
273350362791
273350362791
No, it's a post '76 Mk4 ignition steering lock.
Ignition steering locks weren't even fitted untill October 1970
(maybe it's off one of those pesky time travelling Minis, you know the ones -log book/vin plate says MK3, but every single part except the rear lights are Mk4 or later).
Posted 13 July 2018 - 05:17 PM
Here's the innards of my 72 mk3 lowe and fletcher switch, hope it helps you fit your return spring. I couldn't get a replacement 15 years ago when this one packed up.
Thanks for that.. was perfect, now I have a perfectly working ignition switch. Cant thank everyone enough
Posted 04 October 2018 - 05:35 AM
Hi All,
I had a little win and have some good info for anyone looking to replace their NLA Early MK3 switch. I spent 12 hrs solid at work looking on the net for possible other switches that would fit, I eventually settled on this MGB switch, I took a gamble and bought it and it turned up yesterday and fits well, haven't tried the cowl on it yet but it should fit. It's a Neiman switch and looks pretty similar to the mini one, not that I had one to compare it to.
https://www.google.c...538714208416688
There are other mgb switches which look the same but appear to fit a larger diameter steering column, this particular one is the only one I found with the smaller diameter and it fits the mini. The part number is ADU 3341
