B16A2 Cooper Sportspack
8 replies to this topic
#1 fiestaharry
fiestaharry
  • 295 posts
Posted 29 June 2018 - 06:16 AM
I did have a thread in the Motorbike section but the honda route seems more suited for me.
So
When i bought the shell
stripping
sound deadening removed
New scuttle and dash rail fitted
genuine sportspack arches test fitted
#2 fiestaharry
fiestaharry
  • 295 posts
Posted 29 June 2018 - 06:24 AM
The shell after being lightly blasted and primed
More seam sealer removed
Door test fitted, has had new sills, floor repair panel and door step on this side
Scuttle to wing gaps tiger sealed
#3 fiestaharry
fiestaharry
  • 295 posts
Posted 29 June 2018 - 06:29 AM
So bodywork wise, i have just got the other side to do now, sill, floor and door step. Then general repairs and some filler work.
I have placed an order with Allspeed who are supplying the bare metal Vtec subframe, Driveshafts and Cv joints, which sould be arriving in 8 weeks
I have also managed to find a B16 engine locally, which im going to buy tomorrow if its as described
#4 yeti21586
yeti21586
    He's A Lumberjack And He's OK
  • 3,724 posts
  • Name: Chris
  • Local Club: None
Posted 29 June 2018 - 06:33 AM
Looking good, just out of interest why are you removing the seam sealer??
YetI
Edited by yeti21586, 29 June 2018 - 06:33 AM.
#5 fiestaharry
fiestaharry
  • 295 posts
Posted 29 June 2018 - 06:40 AM
On this car, not sure about others, they have put the seam sealer over bare metal, so there was rust trapped under it, im going to have the remove it all now i know, and primer then tiger seal it all.
May of lasted another 10 years before you saw the signs but i have gone as far as bare metalling it, so may as well start fresh
#6 yeti21586
yeti21586
  • 3,724 posts
  • Name: Chris
  • Local Club: None
Posted 29 June 2018 - 11:29 AM
Fair play, I never realised they put it over bare metal, explains a lot
YetI
#7 fiestaharry
fiestaharry
  • 295 posts
Posted 30 June 2018 - 04:19 PM
Engine now collected, really happy with it, came with more spares than expected.
plan with the engine is to paint the valve cover wrinkle black, gunk the block and gearbox and paint in silver
#8 fiestaharry
fiestaharry
  • 295 posts
Posted 22 July 2018 - 10:27 AM
All the welding finished, primered, masked and sanded the interior panelling. Then raptor was applied
#9 GreaseMonkey
GreaseMonkey
    Has Ratchet, Will Make Noises
  • 3,663 posts
Posted 28 July 2018 - 09:53 PM
Looks like a good base to start with, I look forward to seeing the progress!
