Handbrake Issue
3 replies to this topic
#1 ValentinoRoddy
ValentinoRoddy
    Just On Tickover
  • 9 posts
Posted 23 June 2018 - 08:48 PM
Hi, changed the front and rear handbrake cable on my mk3 mini today but once if finished I noticed it was slightly rubbing on the inside of my tyre. All of the cable is in the correct slots it should be and it works well. The tyre is a Yokohama 165/70 10r so isn’t any wider than normal.
Is the handbrake cable usually this close and if not any ideas how to fix it?
#2 ValentinoRoddy
ValentinoRoddy
    Just On Tickover
  • 9 posts
Posted 23 June 2018 - 08:53 PM
Here an another picture showing how close it is
It isn’t to bad but does touch, you can hear it rubbing when spinning the wheel
#3 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 23 June 2018 - 09:04 PM
Try a couple of washers under the cable bracket at the quadrant end, it will mean wheel and drum off, bolt out
or a 3mm wheel spacer
It might just me rubbing, but imagine that at 50-70 MPH for a while
#4 ValentinoRoddy
ValentinoRoddy
    Just On Tickover
  • 9 posts
Posted 23 June 2018 - 09:27 PM
Thanks for the reply, I’ll give the washers behind the bracket a try tomorrow
