What Are Your Carb And Air Filter Combos?
22 replies to this topic
#1 WillCarter
WillCarter
  • 523 posts
Posted 23 June 2018 - 11:24 AM
Planning my engine build with the help of the yellow bible. I'm deciding on what carb to go with, whether to get a ram pipe and also what air filter to go for. All I know at the moment is that a 40DCOE would probably require bulkhead modification and is probably overkill for a 1275.
The only thing I'm definitely getting at the moment is an MED sub stack.
Cheers,
Will
#2 imack
imack
  • 2,110 posts
Posted 23 June 2018 - 11:35 AM
Vizarded twin hs4's on a 1.5" maniflow steel manifold with ITG/MED filter and stubstacks
#3 WillCarter
WillCarter
  • 523 posts
Posted 23 June 2018 - 11:39 AM
Would you recommend twin carbs? I've heard that an HIF44 is also good
#4 surfblue
surfblue
  • 1,827 posts
Posted 23 June 2018 - 11:51 AM
1 1/4" SU HS2 and metal air-filter box with circular paper element, as per Issigonis!  ;D
#5 unburntfuelinthemorning
  • 1,983 posts
Posted 23 June 2018 - 12:40 PM
Cheers,
Will
It depends what you're trying to achieve but I'd stick with a single SU for good power and economy,  HIF 4 for mild tune and HIF 6 for a hotter motor.
If you're getting an MED stub stack then you don't need a ram pipe.
Air filter choice depends on what sort of noise/looks you like.
#6 cal844
cal844
  • 9,623 posts
  • Local Club: TFMOC
Posted 23 June 2018 - 01:56 PM
Standard 998 or 1275 with stage one kit, they have HS4(one 1275 has a HIF 38) 2 cars run KnN cone filters, the other is a KnN in the standard air box
#7 nicklouse
  • 18,598 posts
Posted 23 June 2018 - 02:22 PM
a single HIF44 will do everything that you need and more. vizzard it if you want. and fit a KN filter in the standard housing and Calver that. the Maniflow steel inlet is very good as is the Minispares alloy one.
#8 timmy850
timmy850
  • 3,340 posts
  • Local Club: MITG
Posted 23 June 2018 - 11:06 PM
My friend has a slightly modified 1275 and had the below:
Twin HS4
Downdraft IDF 45 Weber on RE manifold
Dellorto 40 (essentially a 40DCOE) on a redline manifold
HIF44 with minispares manifold
HIF44 with 7” RE manifold
Of all the different combinations the HIF44 was probably the simplest and best for daily driving. BUT the Dellorto 40 was definitely the most fun to drive and made the best noises. For a weekend car I’d personally pick the Weber/Dellorto 40
#9 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 24 June 2018 - 12:18 AM
Cheers,
Will
A single HIF44 preferably Vizarded will be the best option with a stubstack and a conventional K&N offset type, the cones are not the best.
A 40 DCOE is not really overkill on a 1275, even in a mild state of tune but needs an airbox and manifold of at least 5 inches to be a fraction better than the HIF44, and even then probably only over 4k revs.
But a Weber will always win the best noise  on the planet competition, especially with a straight cut box.
#10 nicklouse
  • 18,598 posts
Posted 24 June 2018 - 12:35 AM
a bit like the above back in the late 80s early 90s i went through a number of carbs on a 1380 with a 286 cam and a worked head but nothing special.
 twin HS4s Visarded.
28-32 DCD
Dellorto  40
Weber 45
all with suitably modded inlets and correct lengths with Air box ram pipes etc and Rolling road set up
and you know what you cant beat an HIF44 for road use. well you can with a proper full injection system.
oh often the Weber can be louder than the exhaust.
#11 Mat
Mat
  • 254 posts
Posted 24 June 2018 - 09:33 AM
HIF44 with the spindle cut down, on a Minispares inlet with a drilled metro air box.
#12 carbon
carbon
  • 2,590 posts
Posted 24 June 2018 - 08:12 PM
1293 running MD266 with Minispares 1.5 forged rockers.
Vizarded Twin HS2s on steel inlet manifold, standard elbows and pair of K&N cone filters fitted upside down with top of air filter case to hold it all together. Just clears bonnet.
#13 Chris1992
Chris1992
  • 2,022 posts
Posted 25 June 2018 - 08:26 PM
I run an HIF44 with K&N filter on my mildly tuned 1275, and it's absolutely bloody brilliant. I used to have twin 1 1/4" SU's and they were hateful things, never want to see them again in my life lol
#14 WillCarter
WillCarter
  • 523 posts
Posted 25 June 2018 - 09:01 PM
Looks like I'm getting an HIF44 then. Slowly building up my list of parts!
#15 minitravellerman
minitravellerman
  • 99 posts
  • Local Club: Minis In Northern Ireland
Posted 06 July 2018 - 07:53 AM
Rally Mini 1000 - standard 1.5" SU with AAU needle and K&N cone filter
1293 Traveller - Manx spec 1.25" twin SUs with AAA needles and standard metal airbox with standard filters
